Old 08-27-2020, 01:23 PM #1
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Throttle body / MAF sensor cleaning
Cleaned them last night. Only took about an hour as the back of the TB was pretty gummed up. Easy job, here is how I did it.
You will need some CRC MAF cleaner AND CRC Throttle Body cleaner. Two different things.
- Disconnect negative battery cable
- Unplug MAF sensor and TB controller connectors
- Undo wire holders mounted on air cleaner/intake assembly, 2 snap ins and
one clip
- Undo intake hose clamp at throttle body
- Disconnect vacuum hose and ventilation hose from cleaner/intake assembly
- Remove air cleaner assembly and set aside
- Disconnect water by-pass hoses from throttle body (no coolant came out,
but had rags under just in case)
- Remove 4 bolts that hold TB
- Clean throttle body as directed on CRC throttle body cleaner bottle
- Remove MAF sensor from intake assembly and clean as directed on the CRC
MAF cleaner bottle
- Put everything back together, torque TB bolts to 15ftlb, plug the the TB
controller and MAF back in, reconnect the battery and fire it up!
Will see over the next few days what MPG does. Pics are after 200,000+ miles.
Remember to plug the throttle body controller back in before you start it back up
Throttle body / MAF sensor cleaning-tb1-jpg  Throttle body / MAF sensor cleaning-tb2-jpg
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 04:35 PM #2
Jivewalker's Avatar
Jivewalker's Avatar
Update after 2+ months. Really doesn't run any different, always ran good. I did gain 0.2 MPG. I figure in 20 years it might pay for the bottles of cleaner.
I am fragile.
Not like a flower.
But like a bomb.
Old 11-19-2020, 11:42 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Just a suggestion: Top Tier gas has more cleaners and other additives than non-top tier gas, so if you use that exclusively, you may never have to clean your fuel system again.
To see brands of Top Tier Gas, go to :
TOP TIER™ Gasoline Brands
Most national brands and Costco are top tier gas. The inferior gas is often sold at convenience stores.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 11:53 PM #4
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Top Tier fuel has nothing to do with the back-side of the throttle body getting dirty. That dirt is coming from the PCV system and that "top tier" fuel does not keep anything cleaner in the PCV system.
The people who sell TT will tell you otherwise, though.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 08:54 AM #5
Jivewalker's Avatar
Jivewalker's Avatar
Yep. And I've always run top tier just by coincidence as the station I use is top tier.
Also, PCV valves are easy maintenance, I change it every so often. It's only $5.
I am fragile.
Not like a flower.
But like a bomb.
assembly , back , body , maf , throttle
2.7 help on throttle body cleaning Kevin K 3rd gen T4Rs 5 10-26-2012 11:41 AM
Cleaning the throttle body DogtorM 3rd gen T4Rs 5 09-08-2011 12:19 AM
Throttle body cleaning pipspeak Maintenance/Detailing 9 04-02-2010 06:19 PM
Cleaning throttle Body Sr54runner 3rd gen T4Rs 2 05-17-2007 09:05 PM
Throttle Body Cleaning fflan513 Maintenance/Detailing 7 06-20-2005 02:13 AM
