11-06-2020, 06:13 PM
#31
Originally Posted by jimday1982
Can we expect these new Pro wheels to come on all 2021 trims that feature Pro wheels, a la the Venture?
bump for this question; also curious which wheels the '21 Venture comes with.
I was at a dealership in Dallas this week, and they had several models of 2021 4runner with the PRO wheels added, but they were all the previous version of wheel, and none were the Venture. The Toyota website car builder still show the previous wheels, even for the pro.
11-12-2020, 02:25 PM
#32
I was just at the dealer today. As per usual, need a 2021 TRD Pro VIN number to order these, but I want them for my older 4Runner.
11-24-2020, 06:14 PM
#33
My 2021 Venture came with the black TRD rims, but not the ones OP listed as 2021 Pro wheels (with the red circle around TRD). Mine look like the old ones (red TRD lettering, no circle, slightly diff design).
01-23-2021, 09:26 PM
#34
I like the wheel design but whats up with the red ring on the center caps? The photos of the TRD Pro only had red "TRD" in the center.
2010 TE
03-12-2021, 08:58 AM
#35
Wow, to be honest, I really like them. They look really fresh, new and ... well they are just awesome. At least, that is my own opinion. The only thing that I am aware regarding these rims, is if the center caps would work as great as they have done on the older TRD pro. I would actually like to get some of these rims. I mean, I like them really much, and I guess they would fit my black 4 runner. However, I guess I might be having some problems with the rim offset, I will have to go to the dealer once again...
07-28-2021, 10:54 PM
#36
So does anyone know if these new 2021 TRD pro wheels will fit any regular 5Gen 4Runner? Seems that on the toyota site it says that this part PTR5689210F2 does not fit my 2020 TRD off road premium? I don't want to order them unless I'm sure because they look slick!
07-29-2021, 12:49 AM
#37
they fit. they have worse specs than the TRD trail/off road wheels though. Toyota has been making people use a TRD PRO vin to order TRD PRO parts though.
09-21-2021, 08:04 PM
#38
Real Name: Joe
Real Name: Joe
Tons of these wheels all over the place these days - including ebay. I just purchased 5 for my TRD ORP. Toyota states these wheels are stronger then the older SEMA version. They weigh 25lbs. I paid $201.25 each with free shipping and no sales tax.
I purchased them on-line from Passport Toyota and didn't need to give them my VIN: PTR5689210F2 - Toyota Trd pro wheel - service replacement part | Passport Toyota, Suitland MD
I am in NJ and received them in 3 days after placing the order.
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
09-22-2021, 06:04 PM
#39
Yes, the 2020 & up TRD Pro wheels are "flow form forged" which is stronger than cast wheels. Also, they are made in Mexico vs the older "Pro" wheel which was made in Thailand.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
09-27-2021, 05:29 PM
#40
Real Name: Joe
Real Name: Joe
My new 2021 TRD ORP with her new shoes:
09-27-2021, 09:06 PM
#41
Wow they're looking great!
'04 Limited V6 4x4
01-10-2022, 11:57 PM
#42
Originally Posted by twells
Can anyone confirm the offset and backspacing? Still +4mm and 4.875"? I was hoping they'd be 7.5" or 8" wide and lighter than the TRD Pro Sema wheels.
Offset is wayyy different. 11-mm. with 4-mm. The offset widens the overall vehicle track width by 0.9-in. Since new model sits almost a full inch wider stance, the new rims basically come with built in 1" Spidertrax! These wheels make the 165 70 lood much bigger than they really are. I love the look.
I was set on buying the old version TRD Pro rim because I actually like the color a lot better. But once I saw the wider stance, I knew I made the right choice. It just looks meaner and less of the "skipped leg day" look that the old TRD Pro wheels kinda have, in my opinion. lol
If you're wondering how noticable the wider stance is, even my wife commented on it immediately and she cares nothing, and knows even less, about cars. lol
01-11-2022, 02:19 AM
#43
Somnospeed-that looks great. What kind of lift are you using?
Sent from my SM-G965U1 using Tapatalk
2016 4runner SR5 Premium
2007 4runner Limited
1998 Camry (almost 300,000 miles)
01-11-2022, 10:16 AM
#44
Guessing you mean -11mm offsets with a +4 backspacing?
Looks good. Is your truck leveled up front?
01-11-2022, 11:29 AM
#45
To be honest, those stats were copied and pasted. lol
No, it's not "leveled", it's just level. lol I did 2.5" up front and 1.5" Bilstein springs in the rear. Bilstein says their 1.5" springs settle at 1" for 4wd 4Runner, which has definitely proved true. The stock rear is about 1.5" higher than the front so I figured if I want close to level, having a 1.5" difference between front and rear lift should give it to me. I was right.
Most 4x4 shops told me I needed 2" rear springs but I was not having it. I wanted level and I knew that 2" springs wouldn't get me there.
Ride quality is superb. And this is from a guy who used to autocross a Porsche Cayman so I have a good baseline to compare. lol
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
