Originally Posted by 4runner_dreamer
I wonder what type of lens they are using.. A lot of these cheaper headlamp assemblies use low quality lenses and output won't match that what you would find in something like the Morimoto lenses.
Which makes me wonder if one can take these apart and throw in Morimoto's 2.5" rectangle lenses... Might just do that
I have Spyder headlights on my other vehicle. Pulled them apart and replaced the low beam projectors with some HID projectors which helped quite a bit. It took about an hour per headlight to pull them apart and drill the holes for the new lenses. Doesn't look any different than the H7 halogens they shipped with but light output is better. The DRL strips have two years and 35k miles on them and they still work well.
If you have an early 5th gen, it might be worth getting these and replacing the bad projectors
