Old 01-25-2021, 05:36 PM #151
Nommpop Nommpop is offline
Nommpop is on a distinguished road
Originally Posted by rageandlove View Post
If you can do that on 2021 Pro/Limited models (which have LED low and high beams) I'd try a pair.
And if they work, you'd have a fair bit of demand, I bet.
I haven't thought too far into how to make those headlights work, most of the people upgrading to the Morimoto units have the lower end headlight units. When I get a set in need of modification, I'll tackle it at that time.
Nommpop is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 06:07 PM #152
PLRBRR PLRBRR is offline
PLRBRR is on a distinguished road
@Axix23 @PLRBRR any updates?
Sorry guys! I haven’t had time to get mine much more than out of the box but I’m going to find time this week to figure out my wiring/relay setup and I’ll post my parts order list and schematic. Then some photos when I get them hooked up so others could build their own harnesses if they want.
2017 TRD Offroad; 5160/6112 Bilstein shocks; BB Sliders; BB aluminum skids; stock tire size: KO2s (summer), Blizzaks (winter); More Power Puller hand winch
PLRBRR is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 10:48 PM #153
osugsxr osugsxr is offline
would be interested in this as well
Old 01-25-2021, 11:08 PM #154
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Super! Will be interested to see if you actually need a relay. Was not required in the Tacoma LED conversion harness.
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:51 PM #155
I'm not sure that you really need a relay to drive the low beam LEDs from a halogen type low beam wire harness, but one question is whether the LEDs can handle spikes above 12v, which might happen on the regular halogen wiring... so my thought was to be extra careful and have a 12v regulator that's directly powered by the stock halogen low beam wiring. This would ensure no voltage spikes get to the LEDs. This might be total overkill though if the LEDs have their own built in regulators, which they very well might...
For powering the high beam shutter in the low/high LED projector, I think you really need a relay instead of powering it directly from the stock high beam halogen wire. Reason I'm thinking this is the stock high beams get PWM power when in DRL mode and if this is directly connected to the low/high LED projector shutter I'm not sure what this would do to the shutter...
Not sure which option is better, but my thoughts are one of these should work:
1. Shutter power provided by stock halogen high beam wire and this power is switched by a relay based on the low beam power. Shutter wouldn't see any power unless the low beams are on which wouldn't happen when in DRL mode.
2. Shutter power provided by the low beam wire and switched by a relay based on the high beam power. Shutter wouldn't see any power unless the high beams are at full voltage (not DRL PWM voltage). Not sure how relays behave with PWM, but I think this would work, just would need to read up on this a bit more. Think the effective relay switching voltage has to do with duty cycle of the PWM and the input voltage or something... I like this option better because the relay won't cause any voltage drop for the LEDs. This option requires the halogen high beams to be on with the LEDs when in high beam mode. Think that's ok with me but it will be crazy bright.
Old 01-26-2021, 12:31 PM #156
Adding to my last post... After looking into the Koito LED projectors that Toyota/Lexus uses I'm pretty convinced that the LED driver "blackbox" that I saw in the Toyota wiring diagram is inside the LED headlight housing. Based on this, I think the LED headlights can be powered with the halogen headlight wiring without additional 12v DC regulators.
If anyone with a 2021 can test the voltage going into their LED headlights when the truck is running we'd know for sure (see earlier post for details on the voltage testing).
Old 01-26-2021, 10:32 PM #157
I think you are right and that's good news - less complexity.
Where the 2021 owners that sent pictures a few pages back ... ?
Old 01-26-2021, 11:39 PM #158
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Sorry, been working a ton of extra hours at work.
I got them installed and wired up. Looks amazing. Cut off is insane. No dead spots. Shines out very far! The halogen low beam harness works flawless for the low beam Leds in the 2021.
Photos coming super soon!!!!
Axix23 is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 07:32 AM #159
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
Which headlight unit did go with? The less expensive one is LED low and Halogen high; the more expensive one is LED low and LED high I believe.
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 07:59 AM #160
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Great news.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 06:58 PM #161
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Patiently waiting!
perf0rmance is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 06:44 PM #162
KingPrat's Avatar
KingPrat KingPrat is offline
KingPrat will become famous soon enough
KingPrat's Avatar
I sent you a PM. Let me know if you still don't have access.
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
KingPrat is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 01:51 PM #163
Replied to you. The sets I had are sold, but for anyone else interested I can put you on a list to call when I have more available
Old 01-29-2021, 10:18 PM #164
david05111 david05111 is offline
david05111 will become famous soon enough
I haven't been paying much attention to this for a few months.
So are the bulbs on these replaceable? Ie., are the lights user-serviceable? That's been my big sticking point when looking at something like the Alpharex Nova series. Love the lights, I'm just not sure I trust them to work for years. If Alpharex backed their stuff by like a 10-year, 100% warranty, I would probably have ordered those by now. 2 years seems low.
david05111 is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 10:00 AM #165
Gamma Ray Gamma Ray is offline
Banned
Gamma Ray is just really nice Gamma Ray is just really nice Gamma Ray is just really nice Gamma Ray is just really nice Gamma Ray is just really nice
Banned
So are the bulbs on these replaceable? Ie., are the lights user-serviceable?\
Also curious about this.
Gamma Ray is offline   Reply With QuoteReply With Quote
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
