Old 03-27-2021, 12:55 PM #301
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
9011HIR bulbs > 9005 LED/Xeon retrofit kits.
Cheers! is offline   Reply With QuoteReply With Quote
Old 03-27-2021, 07:38 PM #302
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
2021 Oem 4 Runner led headlights > all
Lol
Axix23 is offline   Reply With QuoteReply With Quote
Old 03-27-2021, 08:27 PM #303
Cheers!'s Avatar
Cheers!'s Avatar
Lol
Yes if we are talking about the limited/TRD pro 2021 LED lights. But if the reply is in context to the sr5/trail edition LED lights where only the low beam is LED and the hi beam still uses a 9005 bulb then a 9011 bulb with out perform a drop in 9005 bulb.
Old 03-27-2021, 08:48 PM #304
Axix23's Avatar
Axix23's Avatar
I tend to disagree with you on that one. About the TRD pro/limited being superior as you won’t be able to change the DRL to led and the Highbeams itself just goes higher slightly.
Nobody cares about the highbeams much as the lowbeam is the most important thing for driving.
If you have a good output lowbeam, there is no need for highbeams. I don’t even need mine after converting to a 2021 Oem led headlights.
You should try it!
Old 03-29-2021, 02:48 AM #305
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Originally Posted by Chris Joy View Post
Thanks, I'll check them out. After the epic Tacomaworld lighting thread, I'm always a little hesitant to swap halogen bulbs for LED's since those tests usually show a pretty dramatic difference in favor of a quality halogen bulb vs. LED's.
Cheers
Chris
This is true, but the focus in the high beam reflector is much less critical than the low beam. It's less of a safety hazard because the reflector is designed to scatter light above the cutoff, and you won't be using them in opposing traffic anyway.
As Cheers said, a 9011 HIR bulb will outperform a replacement LED, but it sounds like you're more concerned about the temperature (color) of the light than performance.
This is true. Reports of the LED high beam of the dual projector model are very underwhelming. Large reflectors are more efficient than projectors so this isn't that surprising. People with the "lower" grade LED headlights actually have higher performing high beams.
I would... disagree. In day-to-day driving under city lights, with other traffic around, sure. Way out in the cuts? You'll appreciate a high beam that performs well. You'll appreciate auxiliary driving lights even more.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 10:50 PM #306
fonka fonka is offline
fonka is on a distinguished road
Originally Posted by kanonengedonner View Post
Anyone that has the 2021 headlight housing could please take a photo or tell me what is the polarity of the LED plug?
I just bought (and received) the new LED 2021 headlights. I swapped the plugs from my older headlights (my right one was wrecked), but I completely forgot about the position the red and black wires when I did the retrofit...
Red and blue are on top. I swapped mine with the oem toyota plug from the harness and it plugs directly in.
fonka is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 02:44 PM #307
vPyrite vPyrite is offline
vPyrite is on a distinguished road
2014 4Runner Trail Premium
What is the current wait time?
vPyrite is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 11:43 PM #308
omega3651 omega3651 is offline
omega3651 is on a distinguished road
Which is the easier swap, the dual LED or the single LED?
omega3651 is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 11:47 PM #309
Single. I haven't seen anyone install the bi-LED into an older truck yet. And the high beam is lower performing then the halogen 9005 in the reflector anyway.
-Tory
Old 04-14-2021, 12:31 AM #310
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
What harness housing did you use?
perf0rmance is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 11:02 PM #311
Axix23's Avatar
Axix23's Avatar
Only the lowbeam led headlights have been swapped in that we know of. I am sure somebody will figure out how to do the Trd pro/limited bi-led headlights. It appears the single leds shine farther and wider with an aftermarket led bulbs in the highbeams.
Old 04-14-2021, 11:49 PM #312
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Did you install yours yet ?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 11:50 PM #313
Anyone have a DIY guide yet or step by step instructions on how to put the single LED onto a 5th GEN with halogens?
Speaking specifically as to how they get the harness to work?
I'm considering buying a set but would like to know how to splice the harness to work on my 2016.
Old 04-15-2021, 03:18 AM #314
Not yet.... looking for the connector needed for the headlights - Toyota said it's not available but the chassis side one is. I'm doing more research to find a easy solution.
Old 04-15-2021, 10:15 AM #315
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Morimoto has found a source - wonder if they would tell you.
rageandlove is offline   Reply With QuoteReply With Quote
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
