Old 04-15-2021, 10:11 PM #316
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Originally Posted by omega3651 View Post
Anyone have a DIY guide yet or step by step instructions on how to put the single LED onto a 5th GEN with halogens?
Speaking specifically as to how they get the harness to work?
I'm considering buying a set but would like to know how to splice the harness to work on my 2016.
Super easy. Get some pre 2015-2020 headlights from a junkyard or etc and take the connectors off and splice them onto the 2021.
Or order them from the person on here that’s listed in my thread.
Axix23 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:14 PM #317
Axix23's Avatar
Axix23's Avatar
Originally Posted by perf0rmance View Post
Not yet.... looking for the connector needed for the headlights - Toyota said it's not available but the chassis side one is. I'm doing more research to find a easy solution.
The harness your looking for only comes with the headlight itself.... only way you will get what you need will be off of another Oem headlight or aftermarket source like morimoto who is able to use their lights for the 2021 4 runners
Old 04-15-2021, 11:38 PM #318
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Are you saying that only 2021 runners have the specific connector to make the oem leds to work ?
Can’t you just make some connectors? Can you post a picture of the said connector.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 01:48 AM #319
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
rageandlove is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 12:26 AM #320
Axix23's Avatar
Axix23's Avatar
no, you need to take the connectors off a 2016-2020 halogen headlights and put that connector onto the 2021 headlights so your factory headlight chassis harness will plug into the 2021 headlights.....
Yes, you could make some butt connectors or jerry rig it to work. I did that initially before to see if the 2021 led headlights would even light up on a pre 2021 4 runner..... I returned those 2021 headlights and decided to purchase some already harness converted 2021 headlights for a lower cost......
Old 04-17-2021, 01:57 PM #321
omega3651 omega3651 is offline
omega3651 is on a distinguished road
Where did you get the already converted LED Headlights?
omega3651 is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 03:45 PM #322
Axix23's Avatar
Axix23's Avatar
2021 Oem Led headlights/fogs installed into 2018 T4R
Old 04-18-2021, 05:00 PM #323
edizzle edizzle is offline
edizzle is on a distinguished road
does anyone know if the 2021 limited LED high/low beams will plug directly into any other 2021 without any modifications? i have a 21 SR% premium with LED lows and would be interested in having high and low LEDs if it is plu n play
edizzle is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 06:02 PM #324
Axix23's Avatar
Axix23's Avatar
No..... it won’t work. You would need some kind of relay like no-leds on a h4 led bulb.
the bi Leds are actually weak Bc it uses the same lowbeam led but raises it tad up. Go on you tube and look.
You will get significantly better output with the sr5/trd off road led headlights by using an affernarket led bulb inside the high beam housing
Old 04-18-2021, 08:55 PM #325
Understood. The LED low beams are great. The high beams are actually perfectly fine. The whiny ***** in me doesn’t like the mid matched color temperatures!! Lol. What are some good recommendations for high beam bulb replacement? Nothing in the blue spectrum!!!!!
Old 04-18-2021, 09:38 PM #326
Axix23's Avatar
Axix23's Avatar
14-21 4Runner: High Beam / DRL LED
Old 04-18-2021, 11:38 PM #327
Jrunr Jrunr is offline
Jrunr will become famous soon enough
I have a 21 TRD Pro and was wondering if there was a way to get the factory halogen (9005) to work with the Bi-LED lights.
Is it possible??
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 03:01 AM #328
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Is it possible??
No. The Pro/Limited headlights use the 9005 bulbs only as DRLs. There's no circuitry that even goes to them for high beam use anymore.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 07:42 AM #329
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Is it possible??
You would have to splice the power and signal wires to actuate the projector solenoid and send power to the halogen simultaneous. I've done this on my bi-Xenon retrofiit, so it's possible on these. Without having a set to look at, I can't say with certainty, but I would look for a splitter that accomplishes this.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:37 PM #330
This is awesome news. Do you know how or where I can get one of these? Or what would possibly be needed to make it work?
Thanks again!
2021 TRD Pro, MGM
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
