12-03-2021, 01:06 AM
#526
^^^Correct. Both are now sold. ^^^
22 AG TRD Sport 4WD |
3M Vinyl wrapped hood, less scoop | 20% Ceramic Tint | AVS Low Pro Window Visors | Diode Dynamics tail as turn conversion | JBA UCA | Toytec Aluma Boss 2.5 | Toytec 1" Bodylift | Toyo Open Country AT3 285/75 | SCS Gen 5 | Morimoto XB LED V2 Headlights | Morimoto XB LED Foglights | Smoked sequential side mirror turn signals | aFe Momentum GT intake | Spidertraxx 1.25" wheel spacers | Relentless Fab BMC |
12-06-2021, 05:47 PM
#527
Checking in to see if anyone here has made progress for converting to the (2022+) 3 wire dual low/high LED housings?
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
12-07-2021, 01:22 PM
#528
This would be nice to get figured out, I seem to find more Pro headlights than Venture/OR/Sport.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
12-07-2021, 01:54 PM
#529
After seeing the pro high beams, I can't blame them. Lol
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
12-08-2021, 01:41 AM
#530
Hello,
I have been reading through the discussions regarding disabling the DRL function on the 5th gen 4runners. In regards to the DRL module hack of bending the pin, does this hack disable the DRL function to only the high beams or does it disable all the lights (ambers, high beams)? The reason I am asking this is because I installed a set of 2021 TRD Pro headlights and ended up tapping into the high beam positive to power the Bi-LED actuator. As a consequence of tapping into the high beams, I needed to disable the DRL function in the infotainment center so that the Bi-LED actuators do not activate when the DRL is active. I would like to still have the amber DRL to function.
12-08-2021, 03:01 AM
#531
Originally Posted by southbayh2oman
Hello,
I answered your question on my visitor page.
Check it out.
Best Regards,
Saker
12-08-2021, 11:35 AM
#532
What was Toyota’s reason for DISABLING the DRL bulbs as highs for the 4Runners with Bi-LED? Use both. Other manufacturers have.
Some very specific years of Range Rovers (2010-2012?) use both. The shield lifts on the Xenon headlights and the separate, high beam only lights come on, as well.
12-08-2021, 11:41 AM
#533
Hello,
What year is your 4runner?
12-08-2021, 12:03 PM
#534
Beats me. They must have used a totally different design team than the ones who designed the new Tacoma headlights. Those ones use LED reflectors instead of this weird mix of projectors, and they're vastly better.
3rd Gen HID vs LED vs Halogen H11 projector headlights | Page 182 | Tacoma World
Whoever was in charge of the 4Runner rollout must have made some weird decisions on a limited budget.
-Tory
12-08-2021, 01:34 PM
#535
2020 TRD pro. I am running the halogen high beams and LED high beam. I figured the halogens will carry a little further than the LED high beams. I was trying to figure out how to isolate the high beam wiring from the drl so I can tap into the high beam only to activate the Bi-LED high beam.
12-08-2021, 02:31 PM
#536
Wait, are you running newer than 2020 headlights? They didn't come with LED until 2021.
-Tory
12-08-2021, 03:00 PM
#537
I installed 2021 TRD pro Bi-LED headlights in my 2020 TRD pro. I tapped the blue LED actuator wire into the existing halogen high beam power and turned off the DRL function in the infotainment unit.
12-08-2021, 03:57 PM
#538
Interesting, I thought it was a black wire that needed to be tapped into for the halogen highbeams to work…
2021 TRD Pro, MGM
12-08-2021, 04:10 PM
#539
Interesting that the DRL can be functioned through the infotainment on the 2020 and up. The 2019 and below DRL are only via the turn signal stock as far as I'm aware.
12-08-2021, 04:15 PM
#540
Or “when a non-automotive engineer hire is made”.
Jokes aside, some serious closed-box, false dichotomy decision making.
