Old 04-25-2023, 08:56 PM #721
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Originally Posted by Leucoandro View Post
Really good thread. After reading through a seperate thread comparing bulbs and headlight assemblies (linked below) I am jelous of those with 2021 T4Rs. I just missed out with my 2020 4Runner.
Headlight comparison stock vs others
We all did but at least you got Apple car play. Swapping in 2021 Oem headlights are super easy and cheap.
Axix23 is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 07:44 AM #722
osugsxr osugsxr is online now
2020 plus head units can be retrofitted with a harness for plug and play. Its been solid so far in the 2017 model.
osugsxr is online now   Reply With QuoteReply With Quote
Old 07-07-2023, 12:39 PM #723
platonicbomb platonicbomb is offline
platonicbomb is on a distinguished road
recommendations for 2012 LED headlight assembly?
I want to replace my OEM, prefer LED but can live with halogen. There are so many options... is there a consensus here on which ones are quality? I'd rather spend $250, willing to spend $500. TIA
platonicbomb is offline   Reply With QuoteReply With Quote
Old 07-07-2023, 01:08 PM #724
Search FB , local marketplace for used OEM take offs
Old 07-07-2023, 11:09 PM #725
My OEM are fine, as OEM go. I'd just like an LED aftermarket, or at least HID. The ones on FB are OEM.
Old 07-08-2023, 06:20 AM #726
you can find OEM led headlights from $100-400 range , its just a pin swap at the connection for plug and play. Think oem led started either in 2020 or 21 its a nice upgrade.
Old 07-08-2023, 10:17 AM #727
mooch91 mooch91 is offline
mooch91 is on a distinguished road
Hi all,
Just wanted to confirm my TLDR summary of the simpler upgrade options for my 2014 halogens (I did read the whole thread - just wanting to make sure).
  • Find 2021 headlights, swap the connector, plug and play, and now you have LED low beam, halogen high beam.
  • Find 2022+ headlights, swap the connector, don't activate the shutter, plug and play, and now you have LED low beam, halogen high beam, though the high beam may not be the same as traditional because of a different reflector.
Not interested in getting involved with the LED high beams at this point.
Do I have the above right? Those who have used 22+ headlights with the halogen high beam, do you find that the high beam is less effective than traditional? DO the 22+ headlights come equipped with the same high beam bulb in the halogen location?
I've been watching Facebook Marketplace for a while and have not come across any reasonably priced LED versions yet. Is there a way to determine from pictures if the headlights are LED? Sellers can be vague at times about the year the headlights come from.
Thanks!
2002 Sport V6 210K - sold
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
mooch91 is offline   Reply With QuoteReply With Quote
Old 07-13-2023, 06:22 PM #728
Pelle328 Pelle328 is offline
Pelle328 is on a distinguished road
How long does the 2021 and newer led low beams last for the oem headlights? From my understanding the low beams are sealed.
Pelle328 is offline   Reply With QuoteReply With Quote
Old 07-14-2023, 09:12 PM #729
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
So does our 2023 ORP have LED headlights?
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-22-2023, 11:34 PM #730
PCMSF PCMSF is offline
PCMSF is on a distinguished road
Just received some 2021 OEM LEDs I bought on eBay for $160 ea. I kept a close eye on listings until someone posted this set in good condition. One light has a partially broken tab that I'm planning to fix with a hot stapler and plastic welder. I also picked up the FSB harnesses w/o shutter for $35 to avoid having to mess with the wiring.
Separately, anyone have advice for how to test these to make sure they are fully functional without pulling the whole front end and grill apart? Will the existing wiring and harnesses reach if I just lay these things on a moving blanket on the engine?
PCMSF is offline   Reply With QuoteReply With Quote
Old 08-23-2023, 08:21 AM #731
might be able to reach it.....removing bumper and install &
reinstall took maybe 30 minutes the first time
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
