OK, got some 2021s from
Nommpop
. They were nicely packaged in Morimoto box ...
Took about 2 hours total to swap, though I could do it way faster the second time around - an hour to remove and replace the bumper cover, 30 to replace lights, 30 to screw around with aiming.
For aiming, I started by matching where the halogens were aimed from the port. They were fairly close to the same aim as the original halogens.
They throw a lot more light with much cleaner cutoff and stair-step.
The next day, I took them and did the 25-feet-from-wall-to-Toyota-specs adjustment. That required me to raise them about 1/2-1 inch.
(My truck has the typical 1/2-inch lean so the driver light is lower than the passenger light ... when setting up the line for the adjustment I drew the line in between the two measurements.)
We'll see if that's too high and if I need to adjust them down.
I threw in a S8 light bar in the grille at the same time since I already had everything apart. It's ridiculously bright.
Overall, super happy with the change. The lights work perfectly, they throw much more light and while cooler in color temperature are not "HID" or "Xenon" white - I'd guess more like 4k.
The transaction with
Nommpop
was smooth - cheaper than the dealer, fast ship, good packaging, connectors were well done.
My wife has a limited, and I'm going to hit him up for a second pair.
You do see the funny rectangles against walls but I don't notice them when driving.
Happy to answer questions.
