Old 11-13-2021, 03:22 PM #496
FiveO4Runner's Avatar
FiveO4Runner FiveO4Runner is offline
FiveO4Runner is on a distinguished road
Fwiw, I have the leds on my 2021 sr5 premium and am very happy with the light output.
FiveO4Runner is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 04:19 PM #497
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
Originally Posted by Dynamo View Post
Is there an easy way to visually identify OEM LED headlights that are low beam LED only versus low and high beam LED? Difference with the connector maybe? Like 2 wires versus 4 wires or something like that? I am looking to buy a used set but want to make sure I get low beam LED only.
The new 2021+ LED housings do not have the grey dust cap behind the low beam projector location.
Cheers! is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 04:59 PM #498
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
I was referring to the LED only housings. Some are low beam only LED and others are low & high beam LED. I was wanting to know how to identify each.
ETA: I think I found the difference. Looks like low beam only LED housings have 2 terminals in the connector whereas low & high beam LED housings have 3 terminals.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 11-14-2021, 06:50 AM #499
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Can someone identify which of the 3 Wires activates the high beam shudder in the Bi LED housings?
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 11-20-2021, 08:30 PM #500
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Originally Posted by arehman11 View Post
You just need the lights from a TRD offroad or sr5 premium for 2021, unpin the connectors from the new ones and your old lights and swap them. It literally takes a couple of minutes for a complete swap per headlight. There’s a YouTube video out there to walk you through it.
So basically the left and right, such as these?
8114035610 - Toyota Headlight. Housing. Lens and amplifier. Unit assembly,. 2014-21. Headlight | Toyota Parts Overstock, Lakeland FL
8107035600 - Toyota Headlight. Housing. Lens and amplifier. Unit assembly,. 2014-21. Headlight | Toyota Parts Overstock, Lakeland FL
And it's simple as unplugging, unbolting, and reverse for install?
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 11-20-2021, 11:17 PM #501
Dynamo's Avatar
Dynamo's Avatar
So earlier this week I was able to snag a set of OEM LED headlights from a '21 Venture off of ebay. I also bought the OEM LED fog lights from a discount parts dealer. The headlights arrived today and I got everything installed. Overall it was a fairly easy install that took me ~3 hours to do by myself. Removing and reinstalling the front bumper was pretty easy as was swapping out the headlight connectors.
I don't have any good pics but I'm loving the light output as well as the crisp, bright white light. The halogen high beam looks really yellow compared to the LED low beams. Worth it as a mod for me and glad it's all OEM Toyota parts.
ETA: Ok, added some pics.
2019 TRD ORP
Old 11-20-2021, 11:21 PM #502
Dynamo's Avatar
Dynamo's Avatar
Almost. The low beam connectors on your original headlights have to be swapped over to the new LED headlights. There is a youtube video showing how to do it. It's pretty easy to do. Once you have the connectors swapped then it is plug-n-play. Just make sure you test the lights before bolting everything back up to make sure you connector pins in the correct order. If they are swapped then the LED's won't light up.
I believe those headlight part numbers are correct.
2019 TRD ORP
Old 11-22-2021, 03:09 PM #503
GearJunkie88's Avatar
GearJunkie88 GearJunkie88 is offline
GearJunkie88 will become famous soon enough GearJunkie88 will become famous soon enough
@Jrunr - Did you ever figure out which wire activates the high beam shutter? I have a 2022 SR5 Premium and want to use the high beam shutter wire as a trigger wire for an external light bar...
2022 SR5 Premium 4WD
GearJunkie88 is offline   Reply With QuoteReply With Quote
Old 11-22-2021, 03:41 PM #504
I am currently deployed in the Middle East so I am not with my T4R… however, this is a VERY big thing I have been trying to figure out since I got it. All we need is to figure out that high beam trigger and then attach the 9005 bulb to a relay and… BAM!! Significantly better high beams!! ����
(Plus you’ll also have the capability of running additional “driving lights” that are controlled by your auto high beams in the T4R… as you mentioned in your post).
2021 TRD Pro, MGM
Old 11-22-2021, 10:03 PM #505
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
You’ll have to swap your plug from your lights to the new ones by unpinning the connectors. Takes about 5 min total. But the rest of it is standard uninstall and reinstall.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 11-24-2021, 12:53 AM #506
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Originally Posted by Iris2 View Post
I think replacing LED bulbs is a good choice.
Stock bulbs are just too dim.
OEM LED headlights, sure. LED bulbs in halogen housings are bad.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 03:53 PM #507
2022 wiring: White wire is ground. Blue wire is +12V when low beams are on. Black wire and blue wire are +12V when high beams are on. So, I used the black wire to as the trigger for my light bar.
Old 11-26-2021, 11:59 PM #508
????? ????? is offline
????? will become famous soon enough
With the Diode Dynamics SS3 MAX foglights on. The foglights no longer blow out the low beams which is amazing.
And then there's this little guy that grows when you get close up to a wall
????? is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 09:07 AM #509
osugsxr osugsxr is offline
do like the yellow fog lights. I installed the OEM led headlight and fog lights on a 17 SR5P and love the upgrade. Still need to adjust the height to my liking some though but I dont drive much at night now a days.
Old 11-27-2021, 09:49 PM #510
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Damn Jrunr, thank you for you service!!!!!!!!
I’d be worried more about keeping my M4 & my .338 Lapua clean more than my freaking high beam trigger wire!
Stay safe. Oorah !
Best Regards,
Saker
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
