11-28-2021, 09:17 AM
#511
Originally Posted by Saker
Damn Jrunr, thank you for you service!!!!!!!!
I’d be worried more about keeping my M4 & my .338 Lapua clean more than my freaking high beam trigger wire!
Stay safe. Oorah !
No need to worry about that. Clean is life for my babies!! lol
With the T4R though, it was just something that really bugged the s*!t out of me with those damn headlights. Toyota just killed their headlights... and i need to be able to see!! lol
2021 TRD Pro, MGM
11-28-2021, 12:56 PM
#512
Banned
Real Name: Mark
Banned
Real Name: Mark
Originally Posted by Finslayer83
According to crashnburn80:
These should be the correct part numbers for different versions of the headlights.
Halogen only: ($217.25)
L: 81170-35571
R: 81130-35541
LED w/ Halogen High beam ($647.97)
L: 81070-35600
R: 81140-35610
LED Low/High beams ($697.30)
L: 81070-35610
R: 81140-35620
3rd Gen HID vs LED vs Halogen H11 projector headlights | Page 253 | Tacoma World
11-28-2021, 06:46 PM
#513
Copy you.
I think all 2022 versions of the 4Runner have led lows/highs now.
I’m glad my 21 still used halogen in the high. At least I was able to change to a high output led replacement there and it works great.
If you can ditch the drl and re wire to the halogen high socket, you can upgrade and put a high output led there.
Best Regards,
Saker
11-28-2021, 10:35 PM
#514
Copy you.
IÂ’m glad my 21 still used halogen in the high. At least I was able to change to a high output led replacement there and it works great.
Alternatively, the 9011 HIR bulb will fit nicely after a tab trim. It offers a huge brightness increase over the stock 9005 bulb and certainly over any LED drop-in bulb. Also they're only about $20 each, rather than hundreds of dollars. You can check out comparative data here:
3rd Gen HID vs LED vs Halogen H11 projector headlights | Page 263 | Tacoma World
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
11-29-2021, 02:09 AM
#516
I had 9011 HIR in my 2014 , they were brighter that’s a fact.
I found my DDM Sabre LED’s 55 watt 12500/ pair lumens to be brighter.
YMMV
If you think those lights are pulling 55 watts through those tiny heatsinks and over 1000 lumens per emitter, I've got a bridge in Brooklyn to sell you.
-Tory
11-29-2021, 02:57 AM
#517
Hahahahaha
I guess you are the expert.
So I guess they are false advertising.
I’m just stating what I see from my own experience.
BTW, I’ve lost nothing in Brooklyn, so not interested in a bridge there anyway.
Have a nice day!
Best Regards,
Saker
11-29-2021, 08:49 AM
#518
Not at all, merely pointing out that companies selling drop-in LED bulbs often inflate their specs to sound impressive so that people will pay exorbitant amounts of money for them. The rating of 12000+ lumens per pair of bulbs (if credible) is likely the theoretical yield of the 12 chips if driven at/over 100% efficiency. The Achilles heel of drop-in LED bulbs is trying to mimic a tiny focal point (like a halogen filament) while still retaining the ability to shed heat from the chip junctions. This is why you end up with these things that look like little key blades with computer fans attached to them, and it's why reporting specs using theoretical lumen counts is often extremely misleading.
It is very possible that they are brighter than their traditional halogen counterparts. And in the open reflector design of the high beam application, things like hotspot focus and glare control are not as critical as they are in the low beam projector.
So your experience may be correct. Just don't feel disappointed if you measure the current draw of the lights and they pull nowhere near 55w. That would require a level of heat capacity not possible with that design.
-Tory
12-01-2021, 03:47 PM
#519
Originally Posted by ElectroBoy
I'm a bit confused here..
At this link
8114035610 - Toyota Headlight. Housing. Lens and amplifier. Unit assembly,. 2014-21. Headlight | Toyota Parts Overstock, Lakeland FL
it says
Fits 4RUNNER
2014-22, w/o LED high beams. There seems to be another part with LED high beams too according to this website. But looks like it's the same part #.
What's the consensus on high beam LEDs? So far it seems folks've being installing lights with low beam LEDs only?
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
12-02-2021, 12:14 AM
#520
Originally Posted by vt100
I can't comment on the part #'s as I bought mine used.
The reason people (myself included) are installing the headlights with low beam LEDs only is because they are virtually a direct swap. The low beam still uses a 2-wire connection. The only modification needed is to swap out the low beam connector. It's easy to do and doesn't require any wire cutting or other permanent modifications. The high beam connector stays the same as the halogen high beam bulb is still used for the high beams and DRLs.
The low & high beam LED headlights are wired differently and I don't think anyone has figured out how to make them work. What was just the low beam side is both low beam and high beam and has a 3-wire connection. And what was just the high beam (halogen) side is now just used for DRLs.
So if you want to install OEM LED headlights into your '14-'20 4Runner you need low beam only LED headlights from a '21 4Runner (SR5 premium, TRD OR, Venture). The Pro and Limited (I believe) have low and high beam LEDs so those won't work.
2019 TRD ORP
12-02-2021, 12:26 AM
#521
Banned
Real Name: Mark
Banned
Real Name: Mark
The part numbers look very similar. Cross check them on another Toyota site like Conicelli.
It seems the consensus opinion (and testing confirms) is that the LED high beams are not as bright as the halogen high beams.
12-02-2021, 03:26 AM
#522
Thank you folks!
Ah... now it makes perfect sense.
12-02-2021, 03:13 PM
#523
If anyones interested, I just posted on the for sale/wanted thread. Selling my LED headlights and foglights from my 22 TRD Sport.
22 AG TRD Sport 4WD |
3M Vinyl wrapped hood, less scoop | 20% Ceramic Tint | AVS Low Pro Window Visors | Diode Dynamics tail as turn conversion | JBA UCA | Toytec Aluma Boss 2.5 | Toytec 1" Bodylift | Toyo Open Country AT3 285/75 | SCS Gen 5 | Morimoto XB LED V2 Headlights | Morimoto XB LED Foglights | Smoked sequential side mirror turn signals | aFe Momentum GT intake | Spidertraxx 1.25" wheel spacers | Relentless Fab BMC |
12-02-2021, 03:17 PM
#524
I'll take them. PM sent.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
12-02-2021, 11:54 PM
#525
Are they dual LED as suspected?
-Tory
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
