Originally Posted by southbayh2oman
uhOh50,
I don't believe anyone has found a way to properly do so yet in the pre-2022 4runners.
I already answered your previous comment about utilizing the high beam function of the Bi-LED headlights in previous posts. I am able to run my DRL with the high beam halogens and activate the Bi-LED high beam and halogen high beams.
Let me see if I understand this, please correct me if I have this wrong.
-You have a 2020 Pro which originally had the halogen low beam / halogen high beam.
-You bought and installed the 2021 Pro headlights that are LED hi beam and LED low beam (bi-LED).
-You de-pinned the plastic LED low beam connectors from your old original headlights in order to install them on your new bi-LED headlights.
-You took out the 3 pins from each new bi-LED headlight connector, then installed the red (pos) and black (neg) into the old low beam headlight connector in the proper positions.
-You plugged your truck’s low beam harness into the modified bi-LED headlight connector.
-You plugged your truck’s high beam harness connector into a 9005 bulb installed in the bi-LED headlight’s (former) DRL position.
-You wire-tapped or soldered an additional length of wire to the blue pinned wire of each new headlight, then connected (soldered or tapped) it to the high beam power wire at each respective high beam harness connector (green wire right, black wire left).
-You disabled the DRL function on the entertainment screen.
-So now you have LED high and low beams, and the halogen reflector lights up as a high beam also. And you have no DRL function.
Is this what you did?
