Old 05-15-2022, 10:57 AM #676
2000se 2000se is offline
2000se is on a distinguished road
Originally Posted by osugsxr View Post
no they arent different, best option is to find a set off FB market or local ads. Ive seen two sets off a 2022 at $350 obo in the past few days (springfield ill, and tampa fl
Any idea on running the LED tail lights? Think the process is same (similar) ?
2000se is offline   Reply With QuoteReply With Quote
Old 05-15-2022, 11:32 AM #677
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
The taillights are all exactly the same since 2014. There is no point in getting tail lights unless you have a 10-13 model with all-incandescent bulbs.
Even the 2014+ taillights only have LED boards for parking/brake lights. The reverse and signal bulbs are still incandescent.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 05-15-2022, 02:48 PM #678
Thank you!
Old 05-21-2022, 04:43 PM #679
Well....I just did this to my 2016 limited. Found a used pair of 2021 OEM LEDs and swapped them out with my standard halogens. I did have to reverse the wires in the plug, but everything went smooth. Removed the front bumper and unplugged all the auxiliary plugs plus the head lights plugs. Swapped out the lights and reinstalled. Now I have low beam LEDs now. High beams are still halogen. We'll see how they perform over the next few days of night driving now.
Thanks to everyone on this thread for the info to assist in this! Excellent.
Old 05-21-2022, 05:51 PM #680
RK1679's Avatar
RK1679 RK1679 is offline
RK1679 is on a distinguished road
RK1679's Avatar
I'm also on the lookout for a set 21/22 OEM LEDs for my 2018.
RK1679 is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 06:22 PM #681
RK1679's Avatar
RK1679's Avatar
Well I have a lead on a set from a 2022 TRD Off Road. Which harness do I need for my 2018 TRD Off Road? Will my DRLs still work properly? Lastly, are the 2022 fog lamps plug and play on the 2018?
Old 05-21-2022, 07:51 PM #682
Everything you need to know is in this post here:
OEM LED headlights conversion adapters for 14-20 halogen 4Runners! | Toyota 4Runner Forum [4Runners.com]
-Tory
Old 05-21-2022, 11:31 PM #683
RK1679's Avatar
RK1679's Avatar
Thanks…very informative. Hope to hear from some who have installed the 2022s in an earlier 5th gen. Mainly curious how the hi beam output is without activating the shutters.
Old 05-22-2022, 08:58 AM #684
The high-beam output is exactly the same, because the reflectors are exactly the same as your current headlights. Nothing changed at all except for the projectors.
-Tory
Old 05-22-2022, 11:29 AM #685
KKTRD-PRO's Avatar
KKTRD-PRO KKTRD-PRO is offline
KKTRD-PRO is on a distinguished road
KKTRD-PRO's Avatar
Is the Set from IL still up? I’m not seeing anything in my marketplace.
2018 Super White TRD Pro
1.25" Spidertrax Spacers | Blackout Emblems | Red Tufskinz 3M TRD Skid Plate Inserts | Red 3/4" D-Ring Recovery Shackles | Pedal Commander - City+4 | Toyota Black Stainless Exhaust Tip | Morimoto XB LED Headlights | Morimoto XB LED Fogs | Somebody stop me...
KKTRD-PRO is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 02:01 PM #686
osugsxr osugsxr is offline
yes it is
登录 Facebook
Old 05-22-2022, 05:18 PM #687
KKTRD-PRO's Avatar
KKTRD-PRO's Avatar
Got ‘em. Thank you!
Old 06-07-2022, 08:50 PM #688
Kunimatsu's Avatar
Kunimatsu Kunimatsu is offline
Kunimatsu is on a distinguished road
Kunimatsu's Avatar
As with the low beam units, they have those goofy shadow artifacts in the beams, just below the cutoffs. My theory is that Toyota used the exact same projector for both models of headlights, and then just depopulated one of the wires for the "cheaper" trims. It would be really funny if someone opens up their SR5 headlights and finds inactive shutters in the projectors. I digress.
Just picked up a pair of 2022 lights and noticed the odd artifacts at the top of each light. I thought something was wrong with them at first, but glad to see I'm not the only one.
Kunimatsu is offline   Reply With QuoteReply With Quote
Old 06-10-2022, 06:17 PM #689
OEM conversion harnesses for LED headlights are now live at FBC!
OEM LED conversion harness
You have the option of including a wire for the shutter, or you can order with only two pins if you have the 2021 low-beam only headlights or if you decide you don't want quad high beams. These are built to order and allow you to convert your 14-20 4Runner with halogen headlights to the new 2021 and up factory LED headlights.
any luck on the bi led high beams working?
Old 07-04-2022, 03:52 PM #690
Dave is working on a plug n play set right now. I'll update soon.
-Tory
4runner , day , fill , headlights , led , limited , night , owners , premium , sr5
2015 4Runner retrofit headlights Bob43 5th gen T4Rs 5 05-11-2021 08:41 AM
So what's the over under of us retrofitting these 2021 full LED headlights coming? NorthPark 5th gen T4Rs 29 07-11-2020 02:25 PM
Are 2021's getting led headlights? 2chains 5th gen T4Rs 9 04-18-2020 12:21 AM
2021 LED headlights ? Who has a crystal ball? bigbadpoppa 5th gen T4Rs 16 01-05-2020 03:25 PM
Retrofit Headlights on a 2003 4Runner tannerk15 4th Gen T4Rs 11 02-01-2016 09:26 PM
