Old 12-24-2022, 07:14 PM #1
1100 Remington Man's Avatar
1100 Remington Man 1100 Remington Man is offline
1100 Remington Man is on a distinguished road
Locking Rear Differential ?
I don’t know if it’s the cold but I put it in 4L in neutral then push button for rear differential lock and it just flashes and flashes never stops.
Any tips to get it to lock in ?
Temp outside-1F
I did not need it locked just wanted to try it out in the snow.
1100 Remington Man is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 07:39 PM #2
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
Temp outside-1F
How old is the 4Runner? I know when i use mine i'm usually rolling along in 4L when I press the button for the locker. It then sometimes takes a few seconds to sync up and engage. It usually won't engage while your sitting still.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 08:40 PM #3
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
If I've read correctly, E-lockers need a bit of tire rotation to engage. +/- ½ turn of the rear wheel(s).
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 08:58 PM #4
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Put it back in drive then engage locker.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 09:20 PM #5
I will give that a try. It’s a 2022
Old 12-25-2022, 12:58 AM #6
Jeremy556's Avatar
Jeremy556's Avatar
To get it to engage, it needs to not be under load (not holding on a hill) while differentiating the wheels. When I need it (always on a hill), I hit the locker button, put trans in neutral and roll backwards while turning the steering wheel left or right to allow the collar to slide over. This is where I prefer the air locker, just hit the switch and it's on.
Old 12-25-2022, 01:05 AM #7
Whippersnapper02's Avatar
Turn the steering wheel side to side while rolling forward to get the splines to line up.
Old 12-25-2022, 08:49 PM #8
Today I tried moving in Drive slightly that did not work put it in reserve and went right in. Thanks for the tips guys.
Old 12-25-2022, 11:48 PM #9
You figuring it out and posting will help others.
Thank you
differential , flashes , lock , rear , stops
Locking Rear Differential FlyNavy 5th gen T4Rs 54 01-23-2022 05:06 PM
Can you identify this rear locking differential part? BamaDrewski 3rd gen T4Rs 12 01-02-2016 02:09 AM
FS: REAR E-LOCKER Differential Locking Differencial nissanh For Sale: T4R Items 19 05-19-2013 01:44 AM
How important is locking rear differential? jhmoore General Discussions 29 11-29-2011 08:48 PM
Does Rear Locking differential Exist on '02 Sport? SaanichRunner 3rd gen T4Rs 33 03-14-2010 09:56 PM
