Old 08-31-2020, 01:47 AM #16
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
In my opinion no. I think to be sure, the caliper needs to be taken apart and inspected. You will probably need to do that to properly install new seals anyway. I haven't rebuilt a Toyota caliper; but I have done a few single piston calipers over the years. In all of those, the piston is removed; followed by seal removal. Then everything is cleaned (I used brake cleaner) and inspected. Then seals installed, followed by the piston. It might be easier and less of a headache to replace the caliper using yours as a core return and move on. Brakes are really not things to experiment with. If you're not comfortable or not sure you know what you're doing; then pass this job on to someone who does. Safety is more important.
Old 08-31-2020, 06:18 AM #17
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Just go get one from autozone or similar and save yourself the hassle. And excuse my preemptive judgment but if you hit the brakes when the caliper was unbolted you probably can’t rebuild yourself.
Arnezie is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 10:45 AM #18
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
I would get a new caliper and avoid the hassle of trying to rebuild. They are cheap enough.
You are going to have to bleed the caliper now, I would go ahead and do a brake fluid flush on all 4 if you are doing a lot of city driving and had a caliper seize on you already.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
brake , front , pads , side , stuck
4th Gen Front brake caliper rebuild for stuck piston Kmvreter Maintenance/Detailing 38 11-28-2019 10:14 AM
5th Gen Front Caliper Slide Pin Stuck Jake2014 Maintenance/Detailing 7 11-19-2015 09:50 AM
Quick question about stuck 2 of 4 pistons in brake caliper. kacper 4th Gen T4Rs 12 04-13-2015 10:19 PM
Brake Caliper Stuck? Kanger328 3rd gen T4Rs 4 10-07-2013 05:33 AM
