Originally Posted by FishNerd
I had a Hobie Pro Angler 12 which was extremely heavy and for getting it on the roof I used a Yakima Showboat, best thing ever for loading!
Cheers!
That was the option I was leaning towards as it seemed like the simplest design. Did you have a rear spoiler on your 4runner?
What crossbars and saddle mounts were you using? Almost all the mounts are rated for "up to 80lbs". The Outback is 85lb and I know the Pro Angler is about 110lb. I'm guessing if you got away with the 110lb load, 5lbs over for me shouldn't be an issue.
