Hey all,
I just bought a slightly used TRD Pro Bilstein Suspension setup and I'd like to supplement it with some additional lift on the 2014 TEP w/ KDSS on stock suspension.
In addition to the Bilstein TRD kit, my thoughts are to add the following to get it a little extra lift. I also tow a small teardrop camper, and carry light cargo in the rear, so having a little stiffer spring back there might be beneficial.
Any help would be appreciated, especially surrounding issues with the KDSS. I don't want to push that to it's limit, or replace UCAs unless there's a good reason, and from what I can tell this setup shouldn't do that.
If anyone has thoughts, recommendations or concerns, please let me know, and thanks in advance for the help.
1) A BAJA1 - Toytec 1" Front Lift for TRD 4Runner
BAJA1 - 1" Front Lift for TRD BAJA and Pro Edition Tacoma & 4Runners
2) Wheeler's T13 Rear Coil Spring Pair for 10+ 4Runner
3) 150PR10 - OME 10mm Rear Trim Spacer (I've been told the KDSS 4Runners lean, and this should be installed to fix that. Should it go driver or passenger?)
