06-01-2021, 01:50 PM
Rotopax behind Victory bumper
Looking for second, third, fourth and so on opinions.
I have a Victory 4x4 rear bumper with the adventure carriers. I also have a pair of rotopax 2 gallon cans. The cans fit perfectly behind the carriers and rest on the bumper (not suspended at all). There is the tiniest bit of rub between the can and the body.
Here is where I'm looking for opinions.
If I stick some thin rubber in there to stop metal on plastic friction, the only concern I'm left with is gas expanding the can itself. How much should I anticipate these things ballooning? The last thing I want to do is create a bomb behind my hatch, but lord these things fit perfectly.
19 offroad premium, icon stage 3 with overland springs, warn semihide front bumper, victory 4x4 rear bumper, victory skids front to back, warn 10s evo, sso sliders and roof rack, magnaflow exhaust, procharger d1-sc, nitro 4.56 gears and a whole mess of little bits and bobs.
06-01-2021, 02:18 PM
I wouldn't do it, it sits too close. Even if you put foam or rubber back there there will always be vibration and rattling that will rub on the hatch and scuff the paint. The bumper is independent of the body and moves separately so any type of tire or driveline vibration, normal harmonic, and rattling/movement in the swing arm will just keep contacting the rear hatch. Plus as you said, Rotopax's are notorious for ballooning so you want room for it to expand. Put it on the outside of the tire or on the other swing arm.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
06-05-2021, 12:08 AM
Real Name: Neal
Real Name: Neal
I have the 4 gallon rotopax, and they ballon pretty good. I'd say 1/2" easy...
06-05-2021, 04:09 AM
dont do it. If your bumper or tire carrier catches on an obstacle (like driving down a rock formation). it will push that rotopax into your hatch leaving a beauty mark you might not like.
As others have mentioned, if you drive down corrugations, or washboards, you will rub a hole through your rotopax eventually, or rub the paint off your hatch, since your bumper/frame move independently from the body when it flexes.
06-05-2021, 06:46 PM
bummer. sounds like I should mount these like a normal person instead of trying to be fancy. Thanks for the info!
06-05-2021, 06:47 PM
Good points, thanks!
I think you folks are right, I'll just do the boring mount instead of trying to be extra. Thanks!
06-05-2021, 07:02 PM
If you’re really using your Rotopax frequently for supplemental fuel you will quickly realize they are a pretty horrible solution. Switch to Sceptre cans and never look back.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
06-05-2021, 09:55 PM
I'm not entirely sure how useful they are going to be in general. I have to run 91 (preferable 93) but it seems to be easier and easier to get 91 even in the sticks. I have a bottle of torco though just in case ;)
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
