Old 09-07-2020, 10:57 PM #1
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
Rig uneven after air lift install
I just installed an air lift 1000 and noticed that the passenger side is substantially taller than the driver's . I only noticed because I was several yards away working on something else. If I pump the driver side to 25lbs the driver's side is only a hair shorter.
I'm certain that the coils are on the proper sides and both are seated where they're supposed to with the bottom against that lip. It's also not the tires. To be fair, I guess it's possible that it was uneven before the install and I simply didn't notice although I doubt it. I'm open to suggestions. Do these air bags "settle"? Should I just take it off road and hope things even out? Thanks!
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 08:54 AM #2
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
In general the 4R leans to the drivers side already. If the air bags are identical from side to side already, I'd guess this is just carrying it forward after install. My lift included a spacer that leveled it side to side.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 12:09 PM #3
Yeah my spacers came labeled driver and passenger too, but I couldn't discern a difference between the two. I wish I had a photo of the rear on pavement. I'll need to bring both sides down to 5psi and upload a picture of the rear. It looks like George Costanza sitting on a fat wallet. Right now even with driver's up to 25psi I'm not sure that I feel much of a difference in ride quality. Maybe a little if I'm trying to feel for it.
Old 09-10-2020, 11:56 PM #4
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
Did you cut the bump stops the same on both sides?
Verify all hoses still connected and didn't blow off one side?
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 01:28 AM #5
Yes, bump stops were definitely cut at the same node and hoses are all good. It's able to keep pressure. Right now passenger is at 5.5 and driver is 23.5. I tried bringing the driver's down and it went lob-sided again. But you gave me an idea and I think I maybe found the issue. The little rubber cushion on the passenger side is nearly centered on the seat while on the driver's side, it's on but like kinda off-centered and bulging to one side like a herniated disc if you've ever seen one. I think I need to re-center the disc but I'm not looking forward to taking it all apart again. Since I don't need all the space to completely remove the spring, only shuffle it a bit, I hope jacking it up will be enough without having to disconnect the shock and the panhard rod. Don't want to damage the shock though.
Old 09-12-2020, 03:55 AM #6
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
What "little rubber cushion" are you referring to? Are you talking about the cut bump stop or the poly disc that came with the airbags or what exactly?
If you let the air out of the airbags and look at the level, is it still unlevel?
If it is then it isn't the air bags.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 11:26 AM #7
Real Name: Luke
Real Name: Luke
Yeap, that might do it. I had issues with mine flopping about any time the weight of the truck was taken off of them, basically any time it was on jacks. I went back and used some heavy duty outdoor rated double sided tape to secure them to the axle and haven't had further issue.
You should be able to fiddle with everything if you just let the bags go to atmophere (let air out and disconnect the valve or line somewhere). Also a little dish soap will go a long way for lubricating things up. I managed to install mine and never did anything more than jack up the truck and remove the rear wheels.
Old 10-06-2020, 05:53 PM #8
BigTuna02 BigTuna02 is offline
BigTuna02 is on a distinguished road
Damn looks clean! I love the all black color scheme.
BigTuna02 is offline   Reply With QuoteReply With Quote
air , drivers , noticed , side , uneven
Uneven Rear Height after Toytec Lift Install Toyn4Life Engines / Suspension / Wheels / Tires / Audio / Accessories 11 11-24-2019 05:00 PM
Lift kit installed , rear sits very uneven ... Help maxspeed96ct 3rd gen T4Rs 24 03-29-2017 07:29 PM
Uneven Lift? trevo_man 3rd gen T4Rs 22 10-01-2016 08:09 PM
uneven lift marcel 3rd gen T4Rs 13 02-28-2014 11:00 AM
uneven lift dudonkey 3rd gen T4Rs 4 05-27-2012 12:01 PM
