Old 09-08-2020, 12:55 AM #1
acidrane acidrane is offline
acidrane will become famous soon enough
Trailer lights not working
A friend asked me to tow his jetski this weekend (we was towing his boat) and upon connecting the 4pin connector, the lights on the trailer were not working. A quick search showed that a brake controller is not necessary for the 4pin connector. I also read about the 30amp fuse that blows out quite often; I cant imagine a 3 month old car would have a blow fuse but I didn't check.
Is there a switch or setting I need to change? The lights worked on his truck.
2020 TRD Off-Road Premium w/KDSS | Nautical Blue | TRD Cold-Air Intake | MagnaFlow Exhaust | LASfit LED Lights | TRD Pro Grille | FNWheels Countersteer Type X | BFGoodrich K02 275/70 | Bilstein 6112/5160 w/Eibach 1" Springs | Dobinsons UCA | WeatherTech Window Deflectors | C4Fab Sliders | C4Fab Ladder | Sherpa Crestone | Ironman 4x4 Awning
acidrane is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 09:46 AM #2
a bad ground on the trailer will blow your fuse.
Old 09-08-2020, 10:09 AM #3
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
Check the fuse - like mentioned it'll blow if there's a bad ground on the trailer.
Also, check the trailer ground and make sure it's connected and not corroded.
Bill Z is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 06:02 PM #4
Ascole Ascole is offline
Ascole will become famous soon enough
When you say lights do you mean marker lights, turn signals, 4 ways, or all the above?
Easy way to test your 4pin is use a voltmeter on each of the pins.
Trailer wire testing is a little more tedious but definitely start with a bad trailer ground. I ran into a similar issue and after completely tearing out all trailer wiring, I found 12” of corroded wire.
Ascole is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 10:50 PM #5
There was no power to any of the lights on the trailer.
I just checked the fuse on my truck and it was not burnt out. I'll have to check my plug and the trailer wiring. I love electrical issues
Old 09-13-2020, 03:56 PM #6
Check the 4pin on your truck 1st, then the 4 pin harness on the trailer. If it’s the 4pin on the 4runner, you can get a 7 to 4 pin converter and go that route till you get it fixed.
My guess would be something to do with the trailer wiring; corroded or bad ground or something along those lines due to the trailer being submerged. Trailer wiring is pretty easy to figure out as there are no fuses or relays of any kind and is essentially 3 power/ground and 1 harness ground.
Old 09-14-2020, 02:48 AM #7
I'll check it next time I see him. I tried his 7 to 4 connector as well and still nothing. Ironically, the 4pin worked with his truck and the 7pin connector worked with his boat trailer.
4pin , connector , fuse , lights , trailer
Trailer lights not working Kimba2 General Discussions 11 05-22-2021 05:22 PM
Trailer lights not working Hoop 5th gen T4Rs 10 05-11-2021 11:22 AM
Trailer lights not working - tested plug and checked 3 30a fuses in engine bay caskew13 5th gen T4Rs 3 10-07-2019 08:17 AM
Trailer running lights not working abw73 3rd gen T4Rs 1 09-24-2015 04:26 PM
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
