Old 09-09-2020, 12:25 PM #1
Signess Signess is offline
Signess is on a distinguished road
Cruise Control Occasionally Cuts Off
I have a 2018 ORP and I have noticed, though somewhat rare, the cruise control will cut off. The cruise light will remain on, but the "set" light goes off. If there is a pattern to this, it's when I'm going through mountain passes or tighter curves on the freeway, but nothing too steep or tight. Is this a fail safe type mode or should I take to the dealer? Thanks.
Signess is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 01:18 PM #2
TrailNinja TrailNinja is offline
TrailNinja is on a distinguished road
I live in CO and have seen this, too. I've never bothered to research it but I assume it is a rollover avoidance measure based on yaw of the vehicle measured against speed.
TrailNinja is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 01:35 PM #3
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Both situations you described you shouldn't be using cruise to begin with. Not sure what's causing it to cut off, but the system is dumb and is only really good at holding the speed on flat straight roads.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 01:38 PM #4
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
My 2018 Pro has the same problem. I drive with the cruise on driving home late at night on the streets. 40mph speed limit. Once I come to a couple of slight curves in the road, it shuts off. I use cruise to and from work as there are lots of motorcycle cops on the drive through residential areas. Frustrating, since my 2001 had the same exact mechanism as my 2018 and didn’t have these problems. I was hoping that after all these years that my 2018 should have a better cruise control that holds it speeds going downhill, etc. I’m guessing they finally addressed this issue with the 2020?
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 02:16 PM #5
gsla72 gsla72 is offline
gsla72 will become famous soon enough
Glad I'm not the only one that hates the cruise control in my truck. It never seems happy keeping a constant speed, overshoots the acceleration back to speed, and won't let it lose more than .5 - 1 mph going uphill before kicking down way too aggressively.
Save that and the horrible intermittent wiper settings I'm a happy man.
2017 Super White TRDOR: Bilstein 6112/5160, SSO Roof Rack, RSG Sliders, C4 Hatch Ladder, TRDP Skid Plate, Falken Wildpeak AT3W's, Scanguage II, ARB Diff Breather, SDHQ ABS Skids, Apex Overland Recovery Points, Outgear Solutions LCA Skids, AJT Design Knobs, Weathertechs, TRD Heritage Grille, Black TRDP F/R Valences, Black Emblems, Console Vault, Full RCI Underbelly, FJToyman Shock Skids
gsla72 is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 10:30 AM #6
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
No dealer will be able to put in the time or effort to reproduce this feature. Even if they did, the fix would be beyond their mental grasp.
nglayton is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 12:47 PM #7
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
>"Glad I'm not the only one that hates the cruise control in my truck. It never seems happy keeping a constant speed, overshoots the acceleration back to speed, and won't let it lose more than .5 - 1 mph going uphill before kicking down way too aggressively."
2020 model cruise control has been re-programmed. Actually works pretty darn good now.
Maintains good speed uphill and downhill. Doesn't overrun or under-run.
One of the few 'improvements' on the 2020 model.
Outweighs the er... 'negative' improvements on the Audio/Navigation systems, those systems are now a bit of a disaster.
Twilghtzone is offline   Reply With QuoteReply With Quote
control , cruise , light , rare , steep
Cruise Control light doesn't come on and Cruise doesn't work. CZ Eddie 3rd gen T4Rs 8 12-15-2012 08:09 PM
Cruise Control?...TSB Reata 5th gen T4Rs 15 12-15-2011 10:01 PM
cruise control cuts out going up steep hills popsmoto 3rd gen T4Rs 8 08-15-2011 12:56 PM
Cruise control DOA fasterdammit Problems & Warranty Issues 4 08-03-2011 11:26 AM
Cruise Control?? Levinz11 Classic T4Rs 3 06-20-2011 10:22 AM
