Old 09-09-2020, 09:40 PM #1
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
Victory 4X4 rear bumper/Rigid cube lights question
I'll be installing the rear bumper Saturday with the 3" cube light already installed, I'm not real sure about how to go about the wiring of the lights. some say I should splice into my back-up lights wire, but I'm not sure I want them coming on every time I back up. so I'd prefer to have them on a separate switch in the center console. I'm not sure how tuff of a job It'll be tearing up the center console so if I have to, I also have some blanks on the left side of the dash and if I remember correctly that panel is easier to work with, it's also closer to the battery. anyhow, I'm a little confused and would appreciate any advise. thanks!
mr.walleye is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 10:37 PM #2
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
I strongly recommend using a relay to power those rear lights, NOT the factory wiring harness. it would work something like this:
FUSED power comes from the battery to your manual on -off switch. power goes back to the relay (18GA wire is sufficient for this) and connect to the 86 pin on the relay. The 85 pin goes to (any) ground. the FUSED "HOT" lead (12ga) will come from the battery into the 87 pin. the power wire to the rear of the truck (also 12ga) will come off the 30 pin, and run to the lights independently of the backup circuit.
This is the simplest method. same philosophy, but you would need a ON -OFF-ON switch to trigger off the backup lights OR the battery direct if you have to have that choice.
Good Luck!!
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
center , console , cube , lights , rear
Victory 4x4 Rear Bumper - 2 Week Impressions PoopSmith 5th gen T4Rs 33 04-01-2024 04:23 PM
The Quick and Easy Rear Bumper LED Cube Retrofit TiN 4th Gen T4Rs 133 04-28-2023 04:12 PM
Litra Cube Lights - 30% off - Limited Time Only! ramonortiz55 Group Buys 9 04-07-2017 05:24 PM
1 set of TiN's " Rear Bumper LED Cube Retrofit" for 4th Gens up to 2005 Sporin For Sale: T4R Items 1 01-05-2016 02:12 PM
2nd gens with ditch/ cube lights? delgadog Classic T4Rs 2 05-28-2014 03:57 PM
