richcrest
While the overhead eyeglass holder is open, reach into the opening on the side closest do the driver. You'll feel and see a little black plastic tab. It slides into the rail that is visible on the side of the eyeglass holder when it is open. It has just gotten jammed in place. All you'll need to do is gently push it either forward or backward and that should solve your issue. Worked for me at least.
