Originally Posted by delloro
Reset your eco meter.
My headlight auto-off setting changed afterwards, I presume that was due to extended time with the battery disconnected.
ECO mode cannot be turned off, or adjusted, or reset. At most, you can turn off the ECO display on the cluster. You'll need an aftermarket throttle controller if you hope to remove the affects of ECO mode. Mine cost $50 on eBay, but I've seen a few much more expensive items that do the same thing mentioned here at T4R.
