Drivers Side "Oh Shit" Handle Mod
I had seen
Saker
do this mod using the kit that
Jasontamu
put together. I ordered the kit from Jason and the necessary Toyota parts from my local dealer.
More info here:
https://www.toyota-4runner.org/5th-g...-2014-t4r.html
From what I can tell, 5th gens come in two color styles for the pillar covers: B0 (silver) or E0 (beige).
Mine is B0:
Grip Handle 74680-60010-B0
Grip Handle Hole Cover 74616-60040-B0
Grip Handle Hole Cover 74615-60040-B0
Here are pics from the install, although Saker's guide is all you really need!
A-Pillar cover removed
Underside
I found that a sharp wood chisel and a hammer was the way to go in order to remove a section of the black plastic
Very clean and easy
Took some measurements and marked the hole
I bought this bit specifically for this project and boy do I love it. I am sure it will be put to good use down the road.
Noice
To test fit alignment I used the end of a spade bit up top and Jason's mount below
I was very satisfied with how it lined up. I think I measured 15x times before I drilled anything. xD
Test fit in the vehicle without the pillar guard
I noted that it caused the pillar cover to bulge a tiny bit near the windshield (follow the black edge of the windshield and you'll see it)
Ultimately determined that I needed to trip out just a tiny bit more of the underside of the cover
Easy
Prepped for drilling to secure the mount to the frame
The frame is not perfectly flat so Jason includes washers to compensate
I should have started this project earlier in the day... night time came quickly and it was a huge PITA working with flashlights... I did get it secured to the frame though
When test fitting the handle again I noted that the protruding plastic on the handle needed to be shaved down just a tad
I took about 1/16th off (right side)
Everything looks flush from the outside
Very satisfied with the outcome! And I find it useful getting in and out of the vehicle.
More to come!
Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
