Old 09-13-2020, 05:34 PM #1
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
Changeable Fog Lights
Been systematically upgrading my lighting when I got my used (new to me) 4runner. Previous owner put in Tacoma fogs which as I understand it are the same ones the 2020 4runners come with (at least in the TRD PRO model).
I really like the idea of moving to upgraded Baja Designs Squadrons in white but I have a need for amber in snowy and dusty conditions up in the mountains. As I understand it standalone squadrons could easily put on an amber cover to change the light when needed but because of the fog bezel, can't do that on the 4runner. Is there any other fog kit out there on the market for a 4runner or that someone put together that allows you to switch between colors?
I've seen a switchable bulb for the fog lights? These any good and provide good light for the trail?
JRod0981 is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 07:50 PM #2
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
How to Swap the Lens on Your SS3 LED Pod | Diode Dynamics - YouTube
Diode Dynamics has you sorted...
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 07:57 PM #3
jawkdna's Avatar
jawkdna's Avatar
Just reread your post...
Sadly there is no company that has a solution without removing the fog light housing and doing the swap of the lens... as you stated the 4runner bezel gets in the way.
XXX
Old 09-13-2020, 07:59 PM #4
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
You 100% can change out the lenses on the Baja fogs with the 4Runner mounting kit. You need to remove the lights in order to do it but if you watch the above video, you would need to remove the SS3 lights as well. That’s a complete wash so just get whichever lights you think fit your needs the best.
2018 TRD ORP - Dobinsons IMS 3/2 lift, BFG KO2 285/70/17, LFD 7/8 roof rack, LFD Steel Skid, LFD Bump Out Sliders, TRD intake, Rago Molle Panels, Ellis Precision Shift knobs
CollinJ is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 11:03 AM #5
That's what I figured. Oh well. Not sure if I want to go to that changable bulb either.
Old 09-14-2020, 11:23 AM #6
CollinJ's Avatar
CollinJ's Avatar
Ya so I’ve run bulbs in the factory housings which were fine for a while but later switched to the Baja fog kit. The Diode Dynamic ones weren’t available at the time or I probably would have gone with them since I’ve used their interior LED bulbs in my last 3 vehicles. They’re good people to work with for sure.
If you feel you would benefit from the yellow then I would go with that and only turn the fogs on when you need them. Unless weather the weather is bad there isn’t much reason to run fogs in general but that’s just my opinion.
Old 09-14-2020, 02:18 PM #7
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
It will dim the light output some, but you can put film over the lens. Then take it off/apply more as needed.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 05:12 PM #8
Thought of that too. Perhaps just buying a roll of it when needed and keeping in the back. Thanks man.
Old 09-14-2020, 06:12 PM #9
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I had BD Sport in the combo lens installed before and ordered LaminX 2 inch strips in yellow and in light smoke. I was planning on installing the top half smoke and bottom half yellow tint. Shortly after DD had the white SS3 Sport SAE on sale for $150 shipped so I abandoned the BD project all together and sold everything. I kinda wondered how that customized BD combo would of looked. I enjoy the wider visible SS3 beam pattern more, it's less pencilish than the BDs. SS3 beam pattern also blended in with my side shooter ditch light beam pattern more. Just something to think about while shopping for new fog replacements.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 12:24 AM #10
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
@JRod0981 I had the Baja Design kit back before it included the angled face plate. With the flat face plate you might have enough room to change the lens without removing the fog lights or bumper. It would mean working from both the front and from underneath the bumper but I think it would be possible. You might also consider trying their amber rock guard to fit over top of the flat bezel. But I'm not sure if that would work as easily.
As for how to get it, you'd have to order directly from Baja Designs and request the flat bezel. If there's a comment or request section online you could use that, or just call them directly. Don't forget they offer 10% off and $5 contiguous US shipping with discount code BDFORUMS. I would suggest the black face plates.
This isn't the best angle, but one of the shots I have showing how much gap there is between the OEM bezel and the flat face plates. That gap was almost the same top and bottom, your pinch point would be on the outside edge, and that still had some clearance.
Changeable Fog Lights-20170603_160429-copy-jpg
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 02:33 PM #11
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
My 2013 uses H11 bulbs and these would be switchables for mine. Just search your bulb on Amazon:
Amazon.com: ALLA Lighting H8 H9 H11 LED Switchback Fog Lights Super Bright 8000Lm H11 Switchback Fog/Headlights Bulbs Replacement, 6000K White / 3000K Amber Yellow: Automotive
<<<< is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 08:43 PM #12
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
Eh I’ve replaced the lens on mine without removing them from the 4Runner . You can pop off the black trim on the bumper. It takes a bit more work but it’s doable.
Daikon is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 10:30 AM #13
Originally Posted by <<<< View Post
Thanks. I hadn't seen these. Only the boslla ones.
Amazon.com: BOSLLA H11 H8 H9 LED Headlight Bulbs with 4 Modes, 6500K White/4300K/3000K/Warning Flash for Sunny, Rainy, Foggy, Snowy and Emergency, Low Beam H16 Fog Light 7200LM: Automotive
Both of these options are cheaper than the BD fogs or Diode Dynamics but I know the output won't be nearly as good.
Old 09-18-2020, 11:15 AM #14
HedlightRevolution HedlightRevolution is offline
HedlightRevolution is on a distinguished road
Baja Designs would make for a great fog light, you'd love those! In particular, the Amber ones look fantastic!
HedlightRevolution is offline   Reply With QuoteReply With Quote
4runner , fog , light , put , understand
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
Inter-changeable years Sandspur 3rd gen T4Rs 2 07-18-2013 07:11 PM
FS: 3rd Gen Tail Lights, Corner Lights, Cargo Cover, Running Boards mtravis8 For Sale: T4R Items 1 12-06-2012 03:42 PM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
Are the Progreate Jaos Special 710 offroad lights considered fog or driving lights? msanta Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-05-2006 02:49 PM
