Old 09-14-2020, 12:48 PM #1
orcking orcking is offline
orcking is on a distinguished road
oil changes
did my first oil change and it was very hard as I did not lift the truck.
For people who are doing oil changes,
1- what are you using to lift the car, jacks or ramps, and for both are you letting the car down to drain properly?
2- had hard time to remove the front plastic cover under oil filter, so I just unscrewed one end and let it roll down so I can reach the filter, do I really need to remove the whole thing and how for limited trim?
3- is 10K OK for oil change interval, normal city driving?
orcking is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 01:14 PM #2
Uofoducks15 Uofoducks15 is offline
Uofoducks15 is on a distinguished road
There is a great thread in the sticky on fluid and other basic maintenance. As a new owner myself it has been very helpful.
Uofoducks15 is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 01:17 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I use a floor jack, on the bump on the front skid plate, then jack stands on the frame.
There is a great write up from @Antman with photos and part numbers at:
Oil Change 5th Gen: How To- LOTS of PICS! - Toyota 4Runner Forum - Largest 4Runner Forum
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 01:23 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I use jack stands with the rear wheels blocked and the E-brake on.
I don't know why you had trouble with the cover. I remove the cover and skid plate to be able to access everything easily. Use anti-seize on cover and skid plate bolts. Cover bolts could have been cross threaded by the previous oil changer.
I suggest you check out Antman's oil change thread - it's in the stickies.
I also suggest you check the owners manual for oil change interval for your conditions. However, I think 10K is pushing it. I do 7K but I don't do much city driving.
Old 09-14-2020, 01:53 PM #5
I saw that, however the skid plate on my 2020 Limited, look a little different from the pics shown.
Some of the front screws of the skid plate are hidden . I just removed the back screws and the skid plate leaned downward so I can barely reach the filter.
Old 09-14-2020, 02:12 PM #6
Whippersnapper02's Avatar
[QUOTE=orcking;3543961]
Nothing but have thought about using my Race Ramps I have for my GTO. They are rated high enough to handle the weight of the Runner.
Not sure if the limited is different but I remove the whole cover. It's not that difficult.
I change mine every 5K miles, not 10K. Also that's about every 6-8 months for me so oil age comes into consideration. I'm not a fan of leaving oil in that long. 3K is too early for me.
Old 09-14-2020, 02:42 PM #7
flyrv9's Avatar
flyrv9's Avatar
With mine being a 2013, perhaps the plate and plastic covers are different. Seems like there should be a way to release them though.
Old 09-14-2020, 04:33 PM #8
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
Oil changes ? I just use Harbor Freight lift ramps. Lifts the car high enough so you can do some other maintenance under there. If you put 'em in the back and you can easily do the grease fittings.
Have a couple floor lift jacks and stands if I want/need to take the wheels off.
13,000 Lb. Portable Vehicle Ramp Set
Twilghtzone is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 06:23 PM #9
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I use jack stands.
I rotate the tires and under vehicle inspection & maintenance at the same time.
Still a PITA as I have only dirt/gravel to work on.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 08:45 PM #10
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
I have a good garage floor but it helps to save a large section of cardboard to work on. Keeps the floor clean and is easier to move on. Helps on cold winter days too.
Old 09-14-2020, 09:49 PM #11
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
1- I don't lift it at all. Plenty of clearance to get underneath for an oil change. Stock height '19 TRD ORP.
2- My DeWalt 20V 3/8" impact makes quick work of removing and installing bolts. I use it to remove the plastic cover as well as the metal skid plate and oil drain access panel.
3- Probably. I mean that's what Toyota says it should be with normal driving. I have always changed my oil every 5K miles though. I'm sure every 5K is a little overkill but I don't mind, gives me peace of mind.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 10:05 PM #12
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Seems like everyone answered 1 and 2 so Ill answer 3.
I live in LA and drive all over during the weekday and do lots of weekend trips (averaging 30k annually).
My last oil analysis showed there was still enough additive/oil was good enough for a 12k OCI.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 07:36 AM #13
nightflyer's Avatar
nightflyer nightflyer is offline
nightflyer is on a distinguished road
nightflyer's Avatar
I just did my first oil change on my 2020 Venture this weekend. I back mine up into the garage so that the front tires were on the edge of the lip of the concrete. It gave me a little extra room to work with. I didn’t have any issues getting the plastic or the metal skid plate off or back on. The nice thing about doing the first oil change is that everything is torqued correctly from the factory so removing the drain plug and oil filter was a super easy.
nightflyer is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 08:43 AM #14
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Rhino ramps, and every 7500 for me.
I pull my skid completely off to make life easier.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 08:49 AM #15
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Everything about the filter is ridiculous in my opinion. Would have been much simpler had they designed with a spin on filter in a remote location. But I digress.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
car , filter , lift , oil , remove
