Thread Tools Rating: Thread Rating: 2 votes, 1.50 average. Display Modes
Old 12-04-2016, 08:16 PM #1
lmturne1's Avatar
lmturne1 lmturne1 is offline
Real Name: Logan Turner
lmturne1 is on a distinguished road
lmturne1's Avatar
285/75/17 vs 285/70/17?
I currently have a set of Nitto Trail Grapplers installed and am due for a new set within the month. They are on the black TRD T4R wheels and I am contemplating upsizing to 285/75/17 in the same tire. I will attach the specs of the two different sizes below.
Has anyone had a set installed, and if so what suspension setup, wheels (offset), and spacers (if any) do you have installed as well?
Did you encounter any issues at full turn or flex?
My rig is outfitted with an ICON stage 3 kit with the billet adjustable UCA's and no spacers.
In the image provided, the top and bottom lines are the specs in question. Disregard the middle line.
285/75/17 vs 285/70/17?-screen-shot-2016-12-04-6-15-22-pm-png
'15 TEP. | ICON Stage 3 w/ Overland Springs & 700lb Coils | Billet Upper & Lower Links | ICON Track Bar | 285/75 Nitto Trail | Gobi Stealth | ARB Awning | ARB Twin Comp. | ARB Breathers | Geared and Locked | ARB Skids | Pelican Storage | Rigid Ind. | Switchpro | Rago Fab Molle | Pelfreybilt Front | Pelfreybilt Sliders | CBI Rear | Safari Snorkel | Vinyl Wrap | Warn Zeon 10-S |
lmturne1 is offline   Reply With QuoteReply With Quote
Old 12-04-2016, 09:22 PM #2
salong53's Avatar
salong53 salong53 is offline
salong53 is on a distinguished road
salong53's Avatar
I'd just go outside, turn my wheels to full lock in both directions, and measure to see if you'll have clearance for the added radius of the tires. If you have 0.47" to spare, you'll be fine. I doubt you'll have that much room though.
(34.09" - 33.15" = 0.94" divided by 2 equals a 0.47" increase in radius)
2016 SR5 4WD. BFG KO2 275/70R17. FJ TRD Bilsteins + Wheelers 1.25" preload spacers + Eibach rear springs.
salong53 is offline   Reply With QuoteReply With Quote
Old 12-04-2016, 09:33 PM #3
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
or search...
there's only 4,639 tire size threads...I guess one more doesn't matter..
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 12-04-2016, 10:49 PM #4
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
You can get them to fit. Most people run them with 17x8 - 10 offset (4.1BS).
It still requires some trimming.. and a body mount chop. Probably also need to relocate the washer bottle like I did. Caster also needs to be maxed out...
I'm running 305 70 MTRs, which is about the same at 34.1" diameter.
I flex my truck out all the way often.. And I only get a very faint rub here and there. Nothing I can even hear really, but I can see slight evidence under careful inspection.
I would also highly recommend a re-gear to run this size tire. You will really be pushing the limits on stock gearing.
I plan to go up to a 315 next, but will also probably add a 1/4 body lift to help clear a little more tire.
285/75/17 vs 285/70/17?-best2-jpg  285/75/17 vs 285/70/17?-img_20161130_135856068-jpg  285/75/17 vs 285/70/17?-best3-jpg
wfo9 is offline   Reply With QuoteReply With Quote
Old 12-04-2016, 11:16 PM #5
Kodiak555 Kodiak555 is offline
Kodiak555 is on a distinguished road
They fit! That's my exact setup. I put the wheel/tire on without the coilover so I could run the suspension through full articulation. My setup fits with zero rubbing. I am not running spacers. I tried to, but they rubbed when I tested the full articulation. I'm not sure about the BMC, since I performed it prior to my lift install.
Kodiak555 is offline   Reply With QuoteReply With Quote
Old 12-04-2016, 11:41 PM #6
lmturne1's Avatar
lmturne1's Avatar
The consensus after performing a simple search and finding multiple threads addressing my initial question is that a multitude of smaller mods have to be completed prior to installation.
1) BMC, castor adjustment, & possible fender lining trimming
2) Increased (2") bumpstops in the rear
3) Possible regear, depending on how much weight you've added to your rig.
After the addition of the rear bumper in a few weeks, and a front bumper in a couple months I can confidently say that I will have crossed that threshold. So the ends, in my case, won't justify the means.
285/70/17 are here to stay..... at least for the next 35K miles...
Old 04-20-2018, 08:46 PM #7
gmatherly's Avatar
gmatherly gmatherly is offline
Real Name: Greg M
gmatherly is on a distinguished road
gmatherly's Avatar
Real Name: Greg M
I have a similar setup (285/70/17 nitto ridge grapplers on scs Ray 10s and a 3" toytec lift) and I CAN NOT get the rubbing to stop. I'm a few weeks away from the BMC which I have no problems with but today the black plastic behind the front passenger side tire popped off when I drove through a ditch.
I feel like nobody else here is having the issues I'm having so what am I doing wrong!?
2015 Trail Premium-Super White / Gobi Stealth Rack & Ladder / Nitto Ridge Grapplers 285/70/17 / Weather Tech DigitalFit Floor Liners / 3" Toytec-Bilstein 5100s Lift w/ Toytec Superflex Rear Coils/SCS Ray 10s/Yakima Skybox 16
gmatherly is offline   Reply With QuoteReply With Quote
Old 04-20-2018, 10:31 PM #8
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Is it the wheels? I mean usually it’s spacers or some odd backspacing for the wheels from most posts. I assume you have high caster and did the fender liner mod as well right?
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 04-22-2018, 10:20 AM #9
gmatherly's Avatar
Real Name: Greg M
gmatherly's Avatar
Real Name: Greg M
I guess it could be the wheels but so many people use the scs wheels on here, that I'd assume the issue would be documented more. I have a pelfrybilt bumper so the front of the tires do t have any rubbing issues. Caster is maxed out at 4 degrees and I'm prepping for the BMC.
Even with the BMC, it won't address the issue of popping that black piece of plastic off of fender.
Old 03-06-2019, 09:19 AM #10
codyHTX's Avatar
codyHTX codyHTX is offline
codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light
codyHTX's Avatar
285/70 BFG KO2 on 17x7 (~50% tread) vs 285/75 BFG KO2 on 17x8.5
BFG and their whack sizing. spec'd to be taller, but looks wider / larger tread blocks. haven't tried to measure anything yet, I'll update over the weekend
edit:
measured both wheel/tire combos off the vehicle
285/70: 31.5" (with about 0.5" tread worn)
285/75: 33"
i thought the 75's were wider but both measured 9" across the tread. i think its an optical illusion due to a 1.5" wider wheel (better suited for 285) and the tread blocks themselves being physically bigger to accommodate the larger circumference
285/75/17 vs 285/70/17?-img_0760-copy-jpg  285/75/17 vs 285/70/17?-img_0767-jpg
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
codyHTX is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 09:59 AM #11
Decipher's Avatar
Decipher Decipher is offline
Real Name: B-Money
Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough
Decipher's Avatar
Real Name: B-Money
^Excited to see this come together!
33s look right (285/70) but damn does that 285/75 look mean. What a difference!
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 11:05 AM #12
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
FWIW - I have 285/75/17 Cooper AT3s.
Body mount chop was required. Not really even close to fitting without. Lift makes no difference in tire fit in the front, so height doesn't matter. But I have about 2.5" lift (adjustable Fox suspension). Alignment and UCA matter. I have JBA UCAs and alignment set to about 4*. They still rub on the front bumper lip at full lock in reverse a little bit. Otherwise. After a mild BMC there's plenty of clearance at the body mount/fender area.
What stood out most in the Cooper version as compared to a Toyo AT2 was that the 75 was both taller but also significantly narrower tread. They're even narrower than my street tire set, which are 275/65/20 - by almost an inch at the tread.
Mine are on stock wheels. I have some custom 1" spacers that I use. I machined the back side of my OEM wheels for space for the studs. This is getting into a bit more custom machining that you should not DIY unless you have some experience machining aluminum.
Old 03-19-2019, 01:58 PM #13
Spanky4R's Avatar
Spanky4R Spanky4R is offline
Spanky4R is on a distinguished road
Spanky4R's Avatar
Question about your 285/75's. When stuffed & front wheel turned how close are u to the fender, not the well but actual outside edge of it & did you lengthen the front bumpstops? I'm about to order some 285/75 Falkens & just wanna make sure I'm all good.
2015 SR5 Barcelona Red, Icon Lift, Icon Delta Joint UCA's, Falken Wild Peak AT3W's LT285/75R17, Warn Semi-Hidden Winch Bumper, Smittybilt Gen2 X20 10K Synthetic Winch, RCI Aluminum Skids, Shrockworks Dimpled Tread Sliders, Boss 4R Strongbox, OCD Rear Sway Bar Links, Rad Rubber Liners, ARB Rear Diff Breather, Airaid MXP Cold Air Intake, Airaid Superaid Throttle Body Spacer, Blackout Badge Kit, AVS Bugflector II, & WeatherTech Floor Liners.
Spanky4R is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 02:14 PM #14
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
When I was running 285/75 Toyo MT's, the lugs would catch some of the fender screws that hold the fender flares on on the inside of the upper portion of the wheel well. It was not bad, but you could hear it and see wear marks. Since stepping up to 315/70's, I have trimmed out about an inch from the entire fender and flare and now do not have any rubbing. This is with stock bump stops and referencing the front only. In the rear, I have never had any rubbing issues with either size tire.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 02:39 PM #15
Spanky4R's Avatar
Spanky4R's Avatar
Ok, that helps. If it's that close just a washer or two may keep it outta there. They're gonna be AT3W's measured at 33.86
