Old 09-15-2020, 02:44 PM #1
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
How much difference in Caster is ok?
I had my alignment done today at a shop I normally go to, however they seem to have made some personnel; changes.
Somehow they couldn't identify I have adjustable UCA's and told me I would need new ones to get my caster closer to the same on each side. This after I specifically asked them to make sure caster was around 5 degrees. So now I have the left at 4.8 and the right at 5.5 anything to worry about?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 02:48 PM #2
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
id expect a little pulling at highway speed
tm965 is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 02:49 PM #3
comtn4x4's Avatar
comtn4x4's Avatar
yeah seems like it from what little I drove. Irritating. Thanks
Old 09-15-2020, 03:02 PM #4
spartacus's Avatar
spartacus's Avatar
The right side has higher caster by about .5* degrees to my knowledge yours is .7* so little high. If the vehicle is pulling then get them to fix the caster.
Old 09-15-2020, 04:48 PM #5
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
That’s a lot of difference, about what I had before switching to the SPC UCA’s and it pulled noticeably with that much difference.
Caster to 5? Going up another tire size?
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 05:37 PM #6
comtn4x4's Avatar
comtn4x4's Avatar
No, Same size, 285/75 (The St Maxx in 285/75 are pretty tall at 34.1") however, I know it won't rub at that amount of caster. The 305/70 also fit without rubbing at 5 degrees.
I'm honestly surprised they could get it up to 5.5 degrees. I guess I didn't realize the SPC UCA's had that much adjust-ability built in. I don't think I've heard of another brand that can go that high.
Old 09-15-2020, 06:31 PM #7
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I have 4.0 and 4.4 for the crown of the road......285/70/17 and SPC's
83Mule is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 07:20 PM #8
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
Just installed some DK upper arms on a 2\1 lift the other weekend. Got alignment and got 5.4 driver, and 5.7 passenger caster. Was hoping to fit 285\70\17s on 17x8 -10 offset 4.1 back spacing. Tried on my friends wheels which are 17x8.5 -10 offset, not sure what back spacing is on those wheels. He's running KM3s in 285\70\17, and I was still rubbing on the body mount
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 07:30 PM #9
comtn4x4's Avatar
comtn4x4's Avatar
That's good to know that DK's will get that high. Even with my caster as high as it is I have a BMC to ensure no rubbing. Is your body mount chopped? My wheel offset on 9" wheels is +1 fwiw
Old 09-15-2020, 08:05 PM #10
anomalous's Avatar
anomalous's Avatar
No BMC. Was hoping to avoid if I could. I'm thinking I might have a chance to barely clear 285s mounted on my wheels being that my friend's wheels were half inch wider with same offset. So I'm thinking my wheels should give me about quarter inch more clearance ? Yea, I was surprised to get that high of caster angle with the DKs, but I think it has to do with that I'm only lifted 2inches upfront. I'm thinking the caster angles would drop into the 4s if I were to go up another inch upfront. So far it drives really good. tracks super straight at highway speeds
Old 09-16-2020, 04:11 PM #11
Jhalko's Avatar
Real Name: Halko
Jhalko's Avatar
Real Name: Halko
Seems like there is no crown in the road here in Colorado. There is fresh pavement which lasts exactly one winter. Then there is the rutted out, pot holes from the plowing, mag chloride, and huge temp and humidity swings. Haha
Build link:
Old 09-16-2020, 09:45 PM #12
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
I dont think it's a huge deal if the pulling doesn't bother you! If I had your numbers I would actually get them to dial the 5.5 back to the 5 you wanted to get the numbers a little closer, while still not rubbing. As long as you are clearing body mounts at compression I wouldn't worry necessarily about the number. Having the caster numbers a little closer will definitely help your sanity while driving on road.
Sent from my SM-G950U using Tapatalk
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
asked , caster , closer , side , specifically
BMC and Caster Chilow 5th gen T4Rs 4 10-18-2018 07:00 PM
BMC and Caster Chilow 5th gen T4Rs 0 10-18-2018 02:48 PM
Why is my Caster so low? Dirtrider216 4th Gen T4Rs 5 12-12-2017 12:32 AM
Caster difference L-R causing pull?? Help please, YES... ANOTHER alignment question T101 4th Gen T4Rs 2 10-16-2015 04:30 PM
Caster opie74 3rd gen T4Rs 0 03-23-2012 12:04 PM
