Old 09-19-2020, 11:59 PM #16
Jeremy556's Avatar
Jeremy556's Avatar
Originally Posted by phey_05 View Post
Im in a hunt of a shop with road force balancer again.
I hope there's someone on this forum that is from SoCal that can give me a recommendation
https://www.hunter.com/find-equipment/
Old 09-21-2020, 10:21 AM #17
phey_05 phey_05 is offline
phey_05 is on a distinguished road
Originally Posted by SpeedyKevin View Post
Try RPM garage in LA
Thank you Sir, I will call them this morning
phey_05 is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 11:58 AM #18
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Originally Posted by tm965 View Post
honestly dont even bother if the shop doesnt have a road force balancer. it is 100% necessary. it also helps to have a tech that cares/actually tries. the road force numbers on all tires need to be below 15, and the closer to 0 the better.
This. Also tell the tech that you want the tires with the worst Road Force numbers to go on the rear. This helped my shimmy a *TON*
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 01:05 PM #19
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I replaced the ECGS bushing myself. I am not a mechanic. It was an involved process, and you need the right tools, but I got it done.
All that said, it really didn't do anything for me. I had the shimmy, and the bushing doesn't fix that. I echo what others have said, try to get the tires balanced first.
themaestro is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 01:59 PM #20
Thank you for this! I have my mindset that this is the fix, I will have the Tires road force balance first.
Old 09-21-2020, 02:00 PM #21
Thank you! opinion and experience from other owner really helps. I'm glad i posted started this thread.
Old 09-22-2020, 11:43 AM #22
I finally found a shop "America's Tires" that does road force balance. its $25 per tire, ill have all the tires road force balanced and as suggested I'll have the worse tire's to be installed at the back.
So, after the road force balance, do I need to do a wheel alignment immediately?
Old 09-22-2020, 12:35 PM #23
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Holy shit. A road force balance takes just a few minutes. Only maybe 1 or 2 minutes longer than a normal balance. And the machine isn't all that expensive. They're really charging a lot for that.
I worked at a tire shop a long time ago. Like in early 2000's. And we just used a road force balancer as the standard tire balancer. It didn't cost extra. It's literally just a regular balancer that puts a drum against the tire and re-measures the imbalance against the drum. Almost all balancing machines also have the ability to balance the wheel and tire separately and then tell you how to align the tire and wheel for the best overall balance. But most techs don't know how and most shops are too lazy to do it right.
And the machines are not that expensive. The really fancy 3d imaging system machines that measure runout, wheel spoke positions, etc for a next level balance are only $15k.
Old 07-30-2021, 05:40 PM #24
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Is the ECGS bushing good for preventative measures or just for those who are modified? I have stock size KO2 tires on TRD Pro wheels and only a 1" front level. 2015 SR5P. Once in a while a get a vibration and also once in a while I notice the passenger seat vibrating more than normal. Mostly feel it at 90-100km/h (Canada). But I do plan to keep this vehicle for a long time so thinking it would help especially in the long run. Thoughts?
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 11:31 PM #25
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
I replaced mine because of the groaning sound it was making when the component was cold, as in winter temps. Annoyed the heck out of me for a couple years. Toyota techs never heard it of course. Now there is a TSB where they are replacing the entire differential, no thanks.
When I became aware of that part as a solution for trucks experiencing the issue due to CV angles with lifts I had my local guy who is well familiar with the problem (off road shop) pop the one in he carries (Nitro gear). Has been dead quiet since. As for wheel shimmy, I still have the stock Dueller tires and they do it at times, more so in cooler weather. My Michelin snow tires however also running on a stock set of TRD OR rims are perfect. So not sure what to say there but I’d also be in the wheel balancing camp on this particular issue.
Replacing the bearing for prevention measures I think isn’t worth it, while the issue is rare you would be hearing the problem for quite a long time before it failed. And I’m unsure they ever fail actually they just get loud.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
axle , bushing , clamshell , ecgs , install
ECGS Clamshell CV Axle Bushing Install mtbtim 3rd gen T4Rs 65 07-10-2023 09:39 PM
SOLD: ECGS (East Coast Gear Supply) Clamshell Bushing tools newton22 For Sale: T4R Items 0 08-24-2020 03:57 PM
East Coast Gear Supply = 7.5" Clamshell Bushing binqker 3rd gen T4Rs 8 11-21-2019 06:21 PM
ECGS clamshell bushing headcount? JLRSR5 4th Gen T4Rs 9 06-06-2017 09:48 PM
Removal tool for installing ECGS 8" Clamshell Bushing Geerlijd For Sale: T4R Items 0 08-13-2016 06:46 AM
