Old 09-16-2020, 09:01 PM #1
omegadeluz77's Avatar
omegadeluz77 omegadeluz77 is offline
omegadeluz77 is on a distinguished road
Error Lights after lift
Good evening, I had a lift installed and am now getting error lights. I'm worried they may have damaged a sensor wire. The guy at the alignment shop connected the code reader and said all 4 sensors were coding.
I tried the Zero Point Calibration but it seems the data is not erasing prior to recalibration. I went through the first set of instructions and the lights were blinking. When I disconnected the clips to drive, the error lights went back on.
I'm supposed to head out to Hidden Falls tomorrow and now worry the features won't function properly. I have followed the guide on the forums. Any tips?
Error Lights after lift-20200916_200017-jpg
omegadeluz77 is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 09:42 PM #2
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Looks like a broken ABS sensor wire. Usually they get overstretched and set this off, if you had a shop do it I'd be back and make them fix it!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 09:58 PM #3
A family member who works at a shop did it for a nominal fee. I'll need to remedy it myself. Is the vehicle safe to drive in the meantime? I have plans to drive to an offroad park 4 hours away tomorrow.
Old 09-16-2020, 10:53 PM #4
Makes sense, I believe it is a pretty easy repair overall! I would assume fine but not positive - I know there are a lot of posts on here with that issue too.
Old 09-17-2020, 02:20 AM #5
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Mine come on and go off daily. Something I’ve been meaning to fix but never have. My e-brake light also comes on. Usually around turns is when all lights come on. Been driving like that for a few months now no issues other than annoying lights.
I’ll get around to fixing it. Probably on the next oil change
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 02:26 AM #6
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
In my experience you'll be fine to drive it. But you won't have a single traction aid on/off road I believe so be aware of that.
If you have a locker it may work. But I can't even remember if it even allows it to go into 4wd? Someone will correct me on that. I think it will though. Just no crawl control/multi terrain/a-trac.
When I snapped mine I drove it as is for a few days, highway to work and all, until a replacement wire came in. If you can call around any Toyota dealerships on the way and see if they have whichever side wire is damaged, it should be an easy replacement.
I've seen a member on here splice into the damaged wire and repair it themselves which was neat.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 07:29 AM #7
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Most likely a stretched ABS wire. You can drive it but there will be no traction control, no ABS and no 4WD until you remedy the faulty wire. Pretty easy fix if thats what it is. Had it happen to my truck a few years back took my tech a whole 10 min to fix it.
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 02:43 PM #8
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
If you have crawl control, you need to perform the crawl control calibration to finish the zero point.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 12:29 AM #9
Thanks to all for the advice. I switched it into 4wd and think it engaged so i should be alright for now.
Old 06-20-2023, 10:59 AM #10
kimbluetrd kimbluetrd is offline
kimbluetrd is on a distinguished road
What did you end up doing to resolve? I just lifted my 2019 TRD 4Runner and have traction lights and ABS light on.
kimbluetrd is offline   Reply With QuoteReply With Quote
Old 06-20-2023, 04:39 PM #11
BlackPhillip's Avatar
BlackPhillip BlackPhillip is offline
BlackPhillip is on a distinguished road
Echoing what others have said here just to emphasize it's a common issue:
It's an overstretched ABS wire. Same thing happened to me.
BlackPhillip is offline   Reply With QuoteReply With Quote
Old 06-20-2023, 07:53 PM #12
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
they have to replace the ABS sensor wire. If you paid someone to lift your truck, they should warrantee their work.
blinking , error , instructions , lift , lights
p1780 cel park neutral switch error with erratic dash indicator lights Mountain Fun 3rd gen T4Rs 3 11-14-2023 02:50 PM
Lights on dash but no error codes PedroV 4th Gen T4Rs 12 03-29-2020 11:46 AM
HELP please! C1340 error, vsc off flashing and trac lights on KwonRunner 4th Gen T4Rs 5 11-13-2019 07:05 PM
VSC and TRAC lights always on P430 error Im cool with it bassmacka 4th Gen T4Rs 16 06-24-2018 08:31 PM
speedo broke and new error lights 4wordSOUL 4th Gen T4Rs 11 04-13-2013 02:31 AM
