Old 09-19-2020, 04:06 PM #16
valleyforge.1777 valleyforge.1777 is offline
valleyforge.1777 is on a distinguished road
I like the TPMS system. Much better than the system on my 2012 Tacoma where a light goes on and then you get to play the game of trying to figure out which tire has the problem.
valleyforge.1777 is offline   Reply With QuoteReply With Quote
Old 09-19-2020, 05:52 PM #17
xyzzy xyzzy is offline
xyzzy will become famous soon enough
I like the technology used in other manufacturers that use the ABS system for TPMS, it doesn't check the actual pressures in the tires, but uses the rotational speed differences in the tires - seems like quite a simple system to just set the rotational speed range that's allowed and if one or more tires goes outside of that range, turn on a MIL.
Battery operated TPMS sensors are so old school - just like the 4Runner.
xyzzy is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 04:09 PM #18
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
Originally Posted by intenseTRD View Post
i used one of these when i disabled mine. easily removable if you change your mind later.
This is the way...
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 03:04 PM #19
Firesq14's Avatar
Firesq14 Firesq14 is offline
Firesq14 will become famous soon enough
Firesq14's Avatar
Fuse?
What about just pulling the tpms fuse? Obviously not if it controls other items.
Does anyone know if it does?
Firesq14 is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 08:09 PM #20
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Sound like the yaris tpms work around. Reminds me i need to add the switch to the woman's car this weekend.
How to disable tpms in a 5th gen 4runner-screenshot_20210809-183458-jpg
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 06:47 PM #21
charlesanborn charlesanborn is offline
charlesanborn is on a distinguished road
Originally Posted by Fredward View Post
If anyone is curious how to disable tpms in a 5th gen it’s super easy. I noticed there were write ups on 4th gen’s but not 5th gens. The idea is simple and can be acccomllished in many ways but you basically just send a 12v ign to the dash bulb keeping it from grounding, so the light never comes on. Just take off the lower instrument panel, which requires you pull off the piece circled in orange, remove 2 10mm bolts (red arrow), there’s another one on the left you can’t see, it’s behind the little kick panel that you need to mostly remove to get to. Then it’s just the clips in green. Then you just Find the tpms module. There are 4 modules/rows of connectors. This is just left and below the steering wheel. The farthest right one, it’s brown/grey with a black connector, is the tpms module. It’s bolted to the dash with a single bolt on a silver bracket. Grab the plug and cut the green wire in pin 5 (Count from left to right, looking at the back of the connector, starting with the blank space) and connect it to the green wire in pin 7 and done. You can use a quick tap, or strip and solder. And bam. Your done. Now the tpms light will never come on. I’m just not a fan of the expense that comes with tpms. Tpms is a safety feature as a significant percentage of accidents are attributable to flats ad. Low tire pressure but I’m a grown ass man
Question: How do you get those 5 red clips out?
charlesanborn is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 06:49 PM #22
Question: How do you get those 5 Red Clips out? To drop down the lower instrument panel on a 2012 4Runner to gain access to the TPMS Module?
Old 04-19-2022, 11:06 PM #23
Coyotegray's Avatar
Coyotegray Coyotegray is offline
Coyotegray will become famous soon enough
Coyotegray's Avatar
My solution...
How to disable tpms in a 5th gen 4runner-istockphoto-1180797081-170667a-jpg
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
Coyotegray is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 11:57 PM #24
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You have that a bit backwards, the old school method of indirectly measuring tire pressure via the wheel speed sensors came first. Toyota implemented that system on early Highlander, Sienna, and I want to say Avalon/Camry? (we don't get a lot of those out here so I could be wrong). It was a clever way to save money and complexity, but it came with a lot of caveats.
-Rotating tires and not recalibrating the system would set the light..
- The tires wearing too much between calibrations would set the light
-Different tires/brands would set the light (i.e. changing only your two front tires or replacing one due to a nail) with no real way to calibrate it properly. I've had to chase my tail on that a few times...
-Temperature affecting the tire rubber could cause it to set the light because it affects the diameter somewhat.
In tire sensors were the best improvement to that system, they also were legally mandated in the US in all models starting in '07 IIRC. The newest version Toyota uses (which other brands have used for a few years now) uses the combination of the TPMS sensor itself and the ABS wheel speeds to figure out which tire is located where (no need for a silly tire dance Ala GM!)
I'm ambivalent about TPMS systems myself. When I threw new wheels and tires on my 4th gen I bought aftermarket Pacific sensors (same brand Toyota uses) my old ones worked fine after over 10yrs and 100k. I'm not sure what the actual life span is for these things, but it seems like with good habits and care 10yr/100k should be easy for them. The batteries drain quicker if you're always driving around with the low pressure light on or flashing as the system ups the frequency it will ping the sensors, also the sensor with a low pressure will ping much more often until the pressure is corrected. That combined with techs/people not paying attention when they change tires results in a lot of dead/damaged sensors (rather glad Toyota finally is switching to sacrificial stems so the sensor is more likely to survive).
All that being said, if you're being a responsible owner and checking/adjusting your pressures once or twice a month and/or around large temperature swings then a TPMS system is just redundant. So I get why some people want to save some future maintenance costs and just disable the system.
Neat way to turn the light off, though make sure you mention it to the tech so they don't end up chasing it as a problem! Lol
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 12:02 AM #25
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Originally Posted by Grug556 View Post
You know if you keep your spare tires with TPMS next to the truck in the garage, when you start it up you have around 20min or so of driving before it does the recheck and notices the sensors arent with the truck anymore.
When you start it up if they are close (i keep mine on a rack next to where i park in the garage) it shows that they are all good to go! For me I drive to work and i get just near my office before sensor pops on. So maybe 20 miles worth.
Its an orange light.. who cares
The only place one should be accustomed to orange warning lights is British and German autos
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 12:07 AM #26
What’s so old school about a set-it-and-forget-it system in which the batteries last 10 years before you even have to think about changing them?
Also, if you REALLY want to talk about antiquated systems, how about Chevrolet’s TPMS where you have to MANUALLY let it know where EACH tire is again after a rotation? Let a little air out, honk, go to the next tire, let out a little air, honk…
Old 05-06-2022, 09:48 AM #27
Maunmaun Maunmaun is offline
Maunmaun is on a distinguished road
Thumbs up
Regardless of whether I will do it or not, it is a good writeup and we can never have enough of these!
Thank you for taking the time to document it
Maunmaun is offline   Reply With QuoteReply With Quote
Old 05-15-2022, 08:48 PM #28
bdbull bdbull is offline
bdbull is on a distinguished road
Just did this on my son's 2011. FYI, I had to use a red connector instead of blue. The slots in the connector on the blue were too big and they didn't puncture the wire. The red worked perfectly.
bdbull is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 12:49 AM #29
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by patkelly4370 View Post
Had my TPMS light come on a couple weeks ago. Thought I caught a nail or something.
All four tires were 28 psi. Curious as I haven't aired down in a while.
I've kept them at 35 this summer (30 in "winter")
Dead battery in one of the sensors.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 01:05 AM #30
Jakeepoo3's Avatar
Jakeepoo3's Avatar
I did the same after dead sensor battery except I tied a single pole switch into it. Mounted in an available blank which is conveniently right where you'll be working. This allows you to have it factory for morons that don't check their tires. Or switch it off for people that air down frequently and can't stand the stupid light. These guys know how to use a tire guage durp.
5th , green , it’s , left , tpms
5th gen TPMS disable mAtTyGlaz 5th gen T4Rs 83 02-15-2022 05:51 PM
Did you DISABLE TPMS? I want TPMS control module/receiver Ventil8 4th Gen T4Rs 10 03-01-2021 05:59 AM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
