Old 09-17-2020, 12:22 PM #1
Fredward's Avatar
Fredward Fredward is offline
Real Name: Fred
Fredward is on a distinguished road
Fredward's Avatar
Real Name: Fred
How to disable tpms in a 5th gen 4runner
If anyone is curious how to disable tpms in a 5th gen it’s super easy. I noticed there were write ups on 4th gen’s but not 5th gens. The idea is simple and can be acccomllished in many ways but you basically just send a 12v ign to the dash bulb keeping it from grounding, so the light never comes on. Just take off the lower instrument panel, which requires you pull off the piece circled in orange, remove 2 10mm bolts (red arrow), there’s another one on the left you can’t see, it’s behind the little kick panel that you need to mostly remove to get to. Then it’s just the clips in green. Then you just Find the tpms module. There are 4 modules/rows of connectors. This is just left and below the steering wheel. The farthest right one, it’s brown/grey with a black connector, is the tpms module. It’s bolted to the dash with a single bolt on a silver bracket. Grab the plug and cut the green wire in pin 5 (Count from left to right, looking at the back of the connector, starting with the blank space) and connect it to the green wire in pin 7 and done. You can use a quick tap, or strip and solder. And bam. Your done. Now the tpms light will never come on. I’m just not a fan of the expense that comes with tpms. Tpms is a safety feature as a significant percentage of accidents are attributable to flats ad. Low tire pressure but I’m a grown ass man
How to disable tpms in a 5th gen 4runner-d9b19ec9-a0c0-4f0b-ab68-54938c28db63-jpg  How to disable tpms in a 5th gen 4runner-861084f1-ac33-43bb-9028-40a51c43b4ab-jpg  How to disable tpms in a 5th gen 4runner-147e206d-7461-44f1-9b43-6a1a739f0cbd-jpg
Fredward is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 12:25 PM #2
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
This seems like an awful lot of work to save $36 and not have any TPMS again unless you go back and un-do it.
CO-Cygnus is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 12:46 PM #3
spartacus's Avatar
spartacus's Avatar
Good writeup. The tpms sensors gets confused when it's really cold. Ive invested in a good digital tire pressure sensor and check the air pressure everyonce In a while specially before trips and have not had any issues with low pressure ever.
Old 09-17-2020, 01:10 PM #4
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Use the Universal Special Service Tool.
Small piece, goes right on the dash.
delloro is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 05:56 PM #5
jhebert9 jhebert9 is offline
jhebert9 is on a distinguished road
tps sensors
It looks like that disables the light, but not the sensors. Why not just remove the bulb?
jhebert9 is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 07:00 PM #6
delloro's Avatar
delloro's Avatar
Seriously?
Old 09-17-2020, 09:45 PM #7
Fredward's Avatar
Real Name: Fred
Fredward's Avatar
Real Name: Fred
It’s seriously not a lot of work. Like 10 min maybe. You take out two bolts and pull a panel off, then splice one wire. Maybe if you don’t work on your own cars much it would be a 30 minutes. And where are tpms sensors 36 bucks?
As far as the tape, I’m not going to put tape on my cluster This isn’t a 3rd gen lol.
This is a whole hell of a lot easier than removing the cluster to get the bulb out although I did consider that.
The point is I’m have new wheels and Tires and I don’t want to deal with transferring the tpms. Don’t want to pay for it. And want to have both sets of wheels and tires mounted and balanced so I can swap back and forth. I just want good ole valve stems. I dislike nanny systems.
Just trying to share some information for people that want to know.
Old 09-17-2020, 09:58 PM #8
JMZ400's Avatar
JMZ400 JMZ400 is offline
JMZ400 will become famous soon enough
JMZ400's Avatar
You can also place all 4 sensors in a piece off PVC propery pressurized and throw in the back. Light off and no cut wires.
Sent from my SM-A205U using Tapatalk
2012 Trail Edition
2006 SR5 V6 Sold
1981 FJ40
1991 CRX Si - Sort Of
JMZ400 is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 10:03 PM #9
CO-Cygnus's Avatar
CO-Cygnus's Avatar
Everyone’s got their preferences, I get that. Not trying to be aggressively critical.
Personally - TPMS has saved me so many times by letting me know I probably have a nail, screw, or whatever causing a slow leak in my tires before they’re totally flat a trailhead.
I personally avoid modifying anything with any car’s stock electrical system if I can help it.
Partsgeek has sensors for $36. eBay has sets of 4 for like $60.
Old 09-18-2020, 02:17 AM #10
intenseTRD intenseTRD is offline
intenseTRD is on a distinguished road
i used one of these when i disabled mine. easily removable if you change your mind later.
intenseTRD is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 01:53 PM #11
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
You know if you keep your spare tires with TPMS next to the truck in the garage, when you start it up you have around 20min or so of driving before it does the recheck and notices the sensors arent with the truck anymore.
When you start it up if they are close (i keep mine on a rack next to where i park in the garage) it shows that they are all good to go! For me I drive to work and i get just near my office before sensor pops on. So maybe 20 miles worth.
Its an orange light.. who cares
Grug556 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 09:11 PM #12
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I have ignored the light for four years.........my brain doesn't even register it now.
83Mule is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 10:54 PM #13
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Had my TPMS light come on a couple weeks ago. Thought I caught a nail or something.
All four tires were 28 psi. Curious as I haven't aired down in a while.
I've kept them at 35 this summer (30 in "winter")
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 11:51 PM #14
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I did the toggle switch TPMS mod in my 4th gen, and I’m very happy with it. I have wheels with the factory TPMS and wheels with aftermarket TPMS. I just flip the factory TPMS off when I’m using the aftermarket sensors.
Somewhere in the 5th gen procedure, I assume a toggle switch just needs to be spliced in somewhere. (I’m not an electrician, so please correct me if I’m wrong.)
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 09-19-2020, 12:20 AM #15
ads2539's Avatar
ads2539's Avatar
I googled “tpms meme”, and was not disappointed:
How to disable tpms in a 5th gen 4runner-7e3ccc2e-90d7-466e-821a-efe420e4268d-jpg
5th , green , it’s , left , tpms
5th gen TPMS disable mAtTyGlaz 5th gen T4Rs 83 02-15-2022 05:51 PM
Did you DISABLE TPMS? I want TPMS control module/receiver Ventil8 4th Gen T4Rs 10 03-01-2021 05:59 AM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
