Old 05-16-2022, 01:13 AM #31
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by BlackWorksInc View Post
You have that a bit backwards, the old school method of indirectly measuring tire pressure via the wheel speed sensors came first. Toyota implemented that system on early Highlander, Sienna, and I want to say Avalon/Camry? (we don't get a lot of those out here so I could be wrong). It was a clever way to save money and complexity, but it came with a lot of caveats.
-Rotating tires and not recalibrating the system would set the light..
- The tires wearing too much between calibrations would set the light
-Different tires/brands would set the light (i.e. changing only your two front tires or replacing one due to a nail) with no real way to calibrate it properly. I've had to chase my tail on that a few times...
-Temperature affecting the tire rubber could cause it to set the light because it affects the diameter somewhat.
In tire sensors were the best improvement to that system, they also were legally mandated in the US in all models starting in '07 IIRC. The newest version Toyota uses (which other brands have used for a few years now) uses the combination of the TPMS sensor itself and the ABS wheel speeds to figure out which tire is located where (no need for a silly tire dance Ala GM!)
I'm ambivalent about TPMS systems myself. When I threw new wheels and tires on my 4th gen I bought aftermarket Pacific sensors (same brand Toyota uses) my old ones worked fine after over 10yrs and 100k. I'm not sure what the actual life span is for these things, but it seems like with good habits and care 10yr/100k should be easy for them. The batteries drain quicker if you're always driving around with the low pressure light on or flashing as the system ups the frequency it will ping the sensors, also the sensor with a low pressure will ping much more often until the pressure is corrected. That combined with techs/people not paying attention when they change tires results in a lot of dead/damaged sensors (rather glad Toyota finally is switching to sacrificial stems so the sensor is more likely to survive).
All that being said, if you're being a responsible owner and checking/adjusting your pressures once or twice a month and/or around large temperature swings then a TPMS system is just redundant. So I get why some people want to save some future maintenance costs and just disable the system.
Neat way to turn the light off, though make sure you mention it to the tech so they don't end up chasing it as a problem! Lol
Yep a battery died at exactly 100,000 on mine. I integrated a single pole switch when I did this fix so I can switch the system off/on mounted in a switch blank. So it's factory but even better.. 🤠
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 01:33 AM #32
Jakeepoo3's Avatar
Jakeepoo3's Avatar
My dorky video on this haha.
登录 Facebook | Facebook
Old 12-16-2022, 05:37 AM #33
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Question on this procedure. OP used the word “cut wire” but I also see a “wire tap” being used. Can I literally just cut both of these wires and connect them together or do I splice in and put a jumper across them?
Getting new tires tomorrow and going to have them remove TPMS and use rubber valve stems.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 02-24-2023, 11:03 AM #34
richanz richanz is offline
richanz is on a distinguished road
Worked !
Many thanks for the info to disable TPMS. I have battled with an unknown entity that is causing my TPMS light to flash and stay on. Replaced the sensors on my 2018 4Runner and TPMS still randomly goes on.
Very easy to access the unit and spllce the two wires with a quick spllce wire tap. Worked like a charm. I added Tire Pressure Monitor Valve Stem Caps to each tire to keep an eye on pressures without needing TPMS.
Note this link for removing the lower dash panels and HVAC cover .Hidden Midland Radio Step-By-Step Install for 5th Gen 4Runner
richanz is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 12:47 PM #35
Mabeldog Mabeldog is offline
Mabeldog is on a distinguished road
Different wires or reading Pins wrong?
Working on disabling tpms now. When OP mentions left to right, I'm thinking that you read across the top 1-2 being top two pins and then the next row down being 3-4 etc Reading like that's gets me other colors than green and green. If I read down the left side then the 5th one down is green (last one on the bottom left, if looking at the back of the connector while it's plugged in). then 6 would be top right and 7 the second one down on the right side. If I count down the left starting at the top and then down the right from the top I get two green wires. That would be good enough for me if there weren't 3 green wires on the harness. My biggest fear is tapping the wrong two together and causing some expensive problem over $300 worth of tpms sensors. If anyone can chime in on this relatively old thread, I would greatly appreciate it, while I have it torn apart. Thank you!
Mabeldog is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 03:46 PM #36
Jer-2013SR5 Jer-2013SR5 is offline
Jer-2013SR5 is on a distinguished road
After nearly a decade of staring at that damn TPMS light...
Thank you for the clear and easy to follow post. TPMS light has been registering an error (flashing for 60 seconds then coming on) ever since I got my lift and Toyota wanted an arm and a leg to just diagnose the problem. My son is about to take his license test and was told a TPMS light on in the vehicle was an automatic fail so it finally motivated me to make the 'fix'. Now i just have to teach the boy how to feel a low tire when driving.
Jer-2013SR5 is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 11:31 PM #37
If you look at the pics, it is pretty clear...Here is the link . Pin 7 is all by itself..Pin 5 is last in line of the white, red, pink wire ...The furthest green at the corner is not one you want to splice,,,
How to disable tpms in a 5th gen 4runner
Old 02-01-2024, 06:20 PM #38
RICKWILSON RICKWILSON is offline
RICKWILSON is on a distinguished road
May I ASK
May I ask has anyone made a video of this procedure? Thanks for letting me ask.
RICKWILSON is offline   Reply With QuoteReply With Quote
Old 02-01-2024, 06:55 PM #39
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Had my TPMS light come on few days ago. One wheel had bad OEM sensor. I went to Discount Tire (I bought tires from them one and and half year ago). They replaced all 4 sensors (spare doesn't have one in 2013) for $61 each plus programing with no labor charge for dismounting, rebalancing and replacing. No more dash light and OEM monitoring still intact with aftermarket sensors. DT has 7year/75,000mile warranty on them as well. Before disabling entire system I'd say give this option a shot. It worked for me. GL
<<<< is offline   Reply With QuoteReply With Quote
Old 02-24-2024, 09:16 AM #40
13-4Runner 13-4Runner is offline
13-4Runner is on a distinguished road
Many thanks to the OP for these instructions. I finally gave up on my cluster idiot light since I want to sell my 4run and didn't want any issues, real or not.
My scan tool told me which sensor was bad but I didn't feel like going to Toyota and spend perfectly good money on this BS.
My hands are larger so this operation was somewhat more difficult but I got through it with expected results: No more TPMS idiot light!! Took about thirty minutes.
Thanks again!
13-4Runner is offline   Reply With QuoteReply With Quote
5th , green , it’s , left , tpms
5th gen TPMS disable mAtTyGlaz 5th gen T4Rs 84 04-23-2024 07:42 AM
Did you DISABLE TPMS? I want TPMS control module/receiver Ventil8 4th Gen T4Rs 10 03-01-2021 05:59 AM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
