Originally Posted by Jeremy556
Your tires flat spot when sitting. The 4runner steering is sensitive enough for it to be obvious. Jack up a front wheel just barely off the ground by a couple of millimeters, put a flashlight on the ground facing out from just inside the tire, look from the outside of the tire and spin it. The flat spot will be immediately very obvious and is the cause of the cold tire imbalance.
Fyi - if you have a limited, dont try this.
