Old 09-20-2020, 06:19 PM #1
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
Issues installing Icon UCA on 5th Gen
For the Icon UCAs, they come with washers for each side of the bushings where the large pivot bolt goes through. For me, I am having an issue inserting one of the four washer once the large pivot bolt inserts pass the first bushing. The third washer is too large to fit. Did I get the wrong/defect part or am I doing something wrong? Has anyone run into this issue?
Picture is taken from Icon instruction guide.
In green, is the large pivot bolt.
The yellow are the 3 of 4 washers
And the one I can’t fit is the red arrow.
Issues installing Icon UCA on 5th Gen-9579c178-a9f9-4127-9aa4-cf9ed8bcbe5f-jpg
sicnarfone is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 09:16 PM #2
Motory's Avatar
Motory Motory is offline
Motory is a jewel in the rough Motory is a jewel in the rough Motory is a jewel in the rough
Motory's Avatar
Pretty sure when I installed my friend's delta joints, it was an extremely tight fit. I think what we did was put the 2 inner washers in at the same time by greasing them up and wedging them in. Basically, we installed the 2 green washers, then got at least a tapered edge of the the red washers in the spaces. From there we were able to slowly wedge or forcefully move them into place.
If you install 3 and then try to get that last one in by itself, you'll run into the issue you're experiencing where there's no room for it. We also didn't put the bolt through until everything lined up first.
2016 4Runner
Aesthetic: Prinsu + JOE SLAPS, C4 Ladder, Shrockworks Sliders, Rago MSP + Shelf
Suspension: King 2.5 650lb w/ Adjusters, Dobinsons C59-327
Wheels: SCS Ray10 17x9 -38, 35x12.50r17 Yokohama Geolander M/T
Other: Custom Detours of Main Spare Tire Carrier, Freespirit Odyssey 49"
Motory is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 10:38 PM #3
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
You’re not doing anything wrong, they are tight fit. Go to harbor freight, buy a set of pry bars and pry on the rear control arm and it’ll slide right in.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 01:19 AM #4
sicnarfone's Avatar
sicnarfone's Avatar
it was annoying. also for the relocation block, there is a section where you lower the skid plate bracket with washers. In the instructions, it mentioned to place two washers on each bolt and for the one in the front of the truck to have three washers. For some reason, I can't place the factory hardware in with three washers (probably because the factory hardware already has a smaller washer in there) so I am only using two for all three bolts. Will there be any issue? It doesn't seem to have any sway bar rub with two washers.
Old 09-21-2020, 01:21 AM #5
sicnarfone's Avatar
sicnarfone's Avatar
I am placing the washers in as I insert the large pivot bolt from the top engine bay (from image, left to right). The fourth (last) washer has been added yet. I didn't think about greasing up and wedging but there is no way I have the strength to wedge the washer in. the UCA would have to bend out somehow.
Old 09-21-2020, 12:54 PM #6
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
If you start front to back and use a pry bar, pulling the UCA towards the rear of the truck, there will likely be some ever so slight compression of the bushing, allowing you to get the washer in. For the final washer (far back), use the pry bar to pull the entire arm towards the front of the vehicle and see if it can slip in.
You're not trying to bend the arm, just compress the bushings enough to let the washer slide in.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 02:49 PM #7
sicnarfone's Avatar
sicnarfone's Avatar
Gotcha. I will give that a try.
bolt , icon , large , pivot , washer
Icon stage 1 issues JK_ROVR 5th gen T4Rs 14 05-29-2017 09:20 PM
Issues with Alignment of Icon billet Uniball Stem to Spindle sirhamlet 5th gen T4Rs 8 12-18-2016 09:46 PM
issues installing 4xInnovations front bumper 318yota 3rd gen T4Rs 11 02-20-2015 01:44 PM
Icon Coilover Adjustment Issues JustSomeName 4th Gen T4Rs 8 01-19-2013 10:34 AM
Help - Installing Icon lift on TE w/KDSS proquip 5th gen T4Rs 18 03-20-2012 06:51 PM
