Old 09-21-2020, 04:02 PM #1
5point9limited 5point9limited is offline
5point9limited is on a distinguished road
Need help on diagnosing a sound on a GX460. Please Help!
Hello all,
I know this isn't a Lexus forum, but I know that the GX is very similar to the 4Runner. I also know how active this forum is! I am hoping you can help me! Here is what is happening:
I have a 2013 GX460 with 70,000 miles on it. It's a daily driver and does not go offroad. I am getting a thumping noise when turning at very low speeds. I can sometimes feel it in the steering wheel. (Tapping) Even while driving straight. It comes and goes. It is consistent in the steering while turning hard at slow speeds. I was thinking this is a cv joint or wheel bearing. The CV Joint on the driver side does not have any cracks in the boot and a bearing seems a little premature at this mileage. Before I replace the cv joint, has anyone had a similar problem?
5point9limited is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 04:15 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
does the thumping sound rotational? like in time with wheel speed? Do you feel it most when turning either direction, left and right?
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 04:48 PM #3
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
I second where you are going with this. CV shaft
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 05:53 PM #4
Yes, it is in sync with the tire rotation at slow speed. It also seems to make the sound at the same point in the steering. When I turn the wheel at slow speed all the way to the left or right.
Old 09-22-2020, 12:58 PM #5
BTT
Do you think I should go ahead and replace the CV joint?
Old 09-22-2020, 03:43 PM #6
IASTATE01 IASTATE01 is offline
IASTATE01 is on a distinguished road
Another possibility is a cracked brake rotor. Good luck!
IASTATE01 is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 04:01 PM #7
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
To OP: that is a strange one… I am guessing CV or wheel bearing can cause that, but I would think if one of them are causing thumping noise at the low speed you would hear it and feel it in other conditions as well… and with wheel bearing that bad, you probably would be able to feel the “play” on the wheel when that wheel is off the ground.
Also, wheel bearing failure are normally most pronounced with turning one direction (left or right) and almost non- detectible when turning the other direction…
So let me ask you some stupid questions: are you sure that front suspension bolts are tight (cam bolts-LCA) , no worn parts (with big play) like ball joint, steering end links, no broken spring (s), no damaged bushings, etc...? and the last one… are all lug nuts on wheel(s) are tight?
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 09:05 PM #8
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
I would make sure that your alignment cam bolts are tightened to spec.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
bearing , driver , joint , steering , wheel
Limited sound system vs GX460? blakjack23 5th gen T4Rs 6 02-22-2020 03:56 PM
Diagnosing A Grinding Sound/Some Intermittent Starting Issues sdwaltz 3rd gen T4Rs 4 10-09-2017 11:21 PM
Help diagnosing sound. MuddyButt 3rd gen T4Rs 10 09-24-2016 12:13 AM
Help diagnosing belt/pulley sound Natural_Nativ 3rd gen T4Rs 8 03-05-2015 01:58 AM
