Old 09-23-2020, 01:24 PM #16
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
Originally Posted by rightyouareken View Post
When was the last time your diff/tcase fluids were changed? If it's been a while, it might be a good idea to change them. On my 3rd gen I noticed 4hi engage quite a bit quicker after I changed the fluids. Sometimes fresh fluid loosens things back up a bit. Also like previously mentioned, exercising it regularly also helps the solenoids remain free and keeps them from getting sticky.
It is time for a fluid change. I'll do it this weekend and see if it helps. But yes it get regular exercise
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 01:25 PM #17
Soneill's Avatar
Soneill's Avatar
Originally Posted by Thebeastlives View Post
I have a 2008 Tundra, 08, 96, 2019 Trd 4runner and I put them all in 4 wd hi stopped and neutral and get them out of 4 hi by reversing a little. Taught all the sons to do the same over the years and 4 wd has never not worked
Thats good practice but I have never had in issue before the other day. Manual evens says you can be in motion under 50 mph
Old 09-23-2020, 01:38 PM #18
Whippersnapper02's Avatar
Originally Posted by Soneill View Post
I can't even get it to engage at 10 mph on the drit road by my work. If I'm in motion at any speed, it will not engage.
Have you ever changed the fluid? I'd look into it. I'm assuming electronic shifter? Maybe the actuator motor is getting weak.
Old 09-23-2020, 01:50 PM #19
Soneill's Avatar
Soneill's Avatar
Its ready to be changed, going to do it the weekend. It has a shift lever. I was worried about it being the ADD actuator. I wonder if there is an way to test it.
Old 02-16-2021, 11:02 AM #20
Pbuscemi Pbuscemi is offline
Pbuscemi is on a distinguished road
Tire Size
My 4Runner (05 V6 4WD) is currently not shifting on the fly either. I hear a loud clicking or clunking (Not grinding) when I try to disengage.
My tires haven't all come in yet, so the rear ones are 265/75 and the front are 265/65. Would that cause the issue?
Originally Posted by fixer5000 View Post
all 4 tires have about the same amount of wear? diameter same?
Pbuscemi is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 06:49 AM #21
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
Yes, the wheels need to be rotating at the same speed.
Smitty19TRD is offline   Reply With QuoteReply With Quote
back , driving , engaged , put , shift
shift kit 01thunder 3rd gen T4Rs 18 11-08-2017 12:29 PM
NEW SHIFT PATTERNS! October 2016 Ellis Precision Shift Knob Group Buy! Ellis Precision Group Buys 41 08-08-2017 10:23 AM
1-2 slow/sluggish Shift WOT A340E 2004 2WD V6 148K. Shift Solenoid? NCSCOTT 4th Gen T4Rs 1 04-22-2014 07:07 PM
Code P0770-Shift Shift Solenoid E-Please help!! eric70412 3rd gen T4Rs 1 08-16-2010 01:31 AM
Shift on the fly 4WD (96-98 SR5) dursman 3rd gen T4Rs 8 03-26-2005 10:40 PM
