Old 09-22-2020, 08:18 PM #1
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
4 HI won't shift on the fly
1st off: 2011 SR5, 128k, lever shift 4x4
Yesterday morning it was raining and I went to shift into 4 HI while I was driving. The 4x4 light just kept flashing. At one point it seemed like 4 wheel drive had engaged but not completely. I pulled over and stopped it - finally got it to engaged after some fiddling. I tested 4 Low, no problems. Put it back in 4 HI and hit the road. Got up to 60 and had crazy vibration coming from the front drive train. Went to put it back in 2 HI, light just flashed(like before) and 4 HI was still engaged. I drove about a mile and it still wouldn't disengage. I made a right turn to find a place to stop and heard and felt a loud "BANG", truck went back into 2HI.
After more testing of the 4HI transition. I found the truck will only shift into 4HI while sitting still and 4 HI will ONLY disengage when put into REVERSE. I tried driving forward and turning the wheel left and right, no difference. I did find a torn CV boot on the passenger side, that may be the vibration but I'm not too sure. Has anyone run into anything like this? Before yesterday it would shift IN and OUT of 4 HI while driving forward, backward or sitting still without an issue.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 08:09 AM #2
fixer5000 fixer5000 is offline
Real Name: steve
fixer5000 is on a distinguished road
Real Name: steve
all 4 tires have about the same amount of wear? diameter same?
" GET THERE FAST BUT ARRIVE ALIVE "
fixer5000 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 10:07 AM #3
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
I have a 2008 Tundra, 08, 96, 2019 Trd 4runner and I put them all in 4 wd hi stopped and neutral and get them out of 4 hi by reversing a little. Taught all the sons to do the same over the years and 4 wd has never not worked
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 10:23 AM #4
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
Do you exercise it in 4WD regularly?
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 10:50 AM #5
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
When was the last time your diff/tcase fluids were changed? If it's been a while, it might be a good idea to change them. On my 3rd gen I noticed 4hi engage quite a bit quicker after I changed the fluids. Sometimes fresh fluid loosens things back up a bit. Also like previously mentioned, exercising it regularly also helps the solenoids remain free and keeps them from getting sticky.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 11:04 AM #6
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
You shift to 4Hi at 60mph? Not for nothin, but if you need 4hi maybe 60mph is a bit too swift. This isn't an AWD system, can't imagine repeated use of 4Hi at that speed, even on wet pavement is good for it. Just my $.02
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 11:43 AM #7
Whippersnapper02's Avatar
4wd high should be selected on the fly under like 50mph or whatever the manual states. Also let off the throttle when shifting to make it easier on the system. As mentioned, 4wd is not AWD so you really don't need it in the rain.
Old 09-23-2020, 11:48 AM #8
Ronin_Runner's Avatar
Ronin_Runner Ronin_Runner is offline
Real Name: Ken
Ronin_Runner is on a distinguished road
Real Name: Ken
following.
Was also told don't need it in the rain
Ronin_Runner is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 12:35 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
putting it in 4hi in the rain will reduce your traction, not improve it
as you turn all 4 wheels follow different arcs, not just side to side but also front to back. except for on the limited, the 4wd system just has a center transfer case which means there is nothing acting as a differential between the front and rear axle
the safest, best traction for wet pavement is to leave all diffs open and let traction and stability control do their jobs if needed
jhguth is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 12:52 PM #10
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Interesting. How about in snow?
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 01:05 PM #11
the same thing about tires following different paths in snow is still true, but in snow the traction can be so limited you sometimes will need both axles driving and it doesn't matter that the tradeoff is that this technically means at least 1 tire is scrubbing in turns because the traction is limited enough that it would slide or scrub anyways.
also i'm not saying it would generally make a significant difference on wet pavement, just that whatever change would be negative not positive. and as others have mentioned it's just not necessary
Old 09-23-2020, 01:14 PM #12
Soneill's Avatar
Soneill's Avatar
Yes, all the same. Brand new as well
Old 09-23-2020, 01:17 PM #13
Soneill's Avatar
Soneill's Avatar
Thanks for the info. I still don't know why I have to be stationary for it to shift into 4HI. Never had a problem before especially off road.
Old 09-23-2020, 01:19 PM #14
Soneill's Avatar
Soneill's Avatar
I can't even get it to engage at 10 mph on the drit road by my work. If I'm in motion at any speed, it will not engage.
Old 09-23-2020, 01:23 PM #15
Soneill's Avatar
Soneill's Avatar
No, shifted below 50 mph. Then got up to 60 and its never repetitive. She is off road in 4 wheel more often. The main issue is that all of the sudden I have to be stopped for 4HI to engage. Then it will only disengage in reverse.
back , driving , engaged , put , shift
shift kit 01thunder 3rd gen T4Rs 18 11-08-2017 12:29 PM
NEW SHIFT PATTERNS! October 2016 Ellis Precision Shift Knob Group Buy! Ellis Precision Group Buys 41 08-08-2017 10:23 AM
1-2 slow/sluggish Shift WOT A340E 2004 2WD V6 148K. Shift Solenoid? NCSCOTT 4th Gen T4Rs 1 04-22-2014 07:07 PM
Code P0770-Shift Shift Solenoid E-Please help!! eric70412 3rd gen T4Rs 1 08-16-2010 01:31 AM
Shift on the fly 4WD (96-98 SR5) dursman 3rd gen T4Rs 8 03-26-2005 10:40 PM
