09-23-2020, 02:13 PM
Clearance Height?
I'm currently looking for a new place and want to make sure my soon-to-be-arriving 4Runner will clear the garage. My plans are a 2"-3" lift on 285/70/17 tires and a roof rack with light bar. The rack will probably be a Prinsu or Gobi (the smaller version). Does anybody with a similar setup happen to know a rough clearance height that I can use as a reference? Thanks in advance for the help.
09-23-2020, 02:18 PM
The roof rack is what will push you over the edge most likely. My 4runner has a 3/2" lift with LFD roof rails which only add 1" of additional height, and I can still fit into 6'8" parking garages. I'm sure if I went for a full replacement rack, I probably wouldn't fit anymore.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
09-23-2020, 02:38 PM
It depends I think. I'm on 34's with a 2 1/2" ish lift front and rear and I run the ARB roof rack which is very tall (7" off the roof I believe) and I just fit into my 7' garage door opening with a 1/4" to spare. That being said I don't go in 7' parking garages for obvious reasons.
Which rack are you looking at?
Edit never mind about the rack question. I know the Gobi is shorter than my ARB but not a lot. I think you'd be tight in parking garages below 7'
09-23-2020, 02:53 PM
Just order a Gobi rack - by the time you get it, you'll be living somewhere else anyway!
09-23-2020, 03:19 PM
I have that exact set-up with a regular Gobi rack (not stealth) and fit into my two car garage with about 3 inches to spare.
09-23-2020, 03:45 PM
I think you'll be in the neighborhood of 6'4" to the top of the OEM roof rails.
09-23-2020, 04:19 PM
Real Name: Sparky
Real Name: Sparky
I'm 6'3'' ish. Can't be.
My lifted TE with OEM rack is about 6'7'', although I managed to squeak into the SFO parking garage recently so posted clearances might have some wiggle room.
Old and (c)rusty.
09-23-2020, 04:31 PM
Height OEM according to Toyota is 71.5". Add say 3.5" net for lift and tires and you're only at 75" or 6'3".
I guess someone might have to measure? I'm basing my guess on the fact that I can still fit under the 6'8" garage height at work with my awning on that's about 3-4" tall on the side with 1.5" rear springs. With 2.75" rear coils I can't fit. So I figured without the awning I'd probably be right in the range of 6'4".
09-23-2020, 05:00 PM
14 TEP w/ 285/70/17's, 3" Toytec lift, Rhino Rack - Pioneer Platform which totals 77.5". My garage door is exactly 80" to the trim, so I have a little wiggle room for snow. My rack came with side rails, but they put me over the 80" in my current configuration so have been removed. I don't have a light bar, but if I get one it too will need to be low profile, ideally adding little or no height.
09-23-2020, 05:04 PM
Hahhaa, you win today!!
09-23-2020, 06:35 PM
I have a 2017 SR5 with 2.5 front 2” rear 285/70/17 with stock rack, i am at 6’4” or 76” at the top of the rack.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
09-23-2020, 08:35 PM
Sometimes people post things that are too accurate... This is one of those times.
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
09-23-2020, 11:41 PM
Just couldn't resist with the previous comment! However, there was a thread (I think it was here) where a guy raised the header on his garage and added a panel to the door to get the extra height he needed. Might be an option if there is room.
You can also get a little more height (inch or 2 +-) by adjusting cable tensions or springs. I replaced my springs a couple of years ago when one broke and learned a little doing it. Got to be very careful, messing with the springs, if you go this route.
Reason: correction
09-24-2020, 11:45 AM
Real Name: Sparky
Real Name: Sparky
2013 Trail Edition, Icon 3" lift, BFG TA/KO2 285s measures 6 feet 7 and 1/4 inches from the ground to the top of the OEM Trail roof rack.
I literally just measured.
Explains how I squeaked into SFO.
I swear it was almost 6'8" when the lift was new and it had slightly larger overall outer diameter Firestone 285s on it with fatter lugs.
Old and (c)rusty.
09-24-2020, 06:50 PM
Do you know what the actual clearance of your garage is?
