Old 09-23-2020, 02:13 PM #1
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
Clearance Height?
I'm currently looking for a new place and want to make sure my soon-to-be-arriving 4Runner will clear the garage. My plans are a 2"-3" lift on 285/70/17 tires and a roof rack with light bar. The rack will probably be a Prinsu or Gobi (the smaller version). Does anybody with a similar setup happen to know a rough clearance height that I can use as a reference? Thanks in advance for the help.
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 02:18 PM #2
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
The roof rack is what will push you over the edge most likely. My 4runner has a 3/2" lift with LFD roof rails which only add 1" of additional height, and I can still fit into 6'8" parking garages. I'm sure if I went for a full replacement rack, I probably wouldn't fit anymore.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 02:38 PM #3
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
It depends I think. I'm on 34's with a 2 1/2" ish lift front and rear and I run the ARB roof rack which is very tall (7" off the roof I believe) and I just fit into my 7' garage door opening with a 1/4" to spare. That being said I don't go in 7' parking garages for obvious reasons.
Which rack are you looking at?
Edit never mind about the rack question. I know the Gobi is shorter than my ARB but not a lot. I think you'd be tight in parking garages below 7'
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 02:53 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Just order a Gobi rack - by the time you get it, you'll be living somewhere else anyway!
Old 09-23-2020, 03:19 PM #5
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
I have that exact set-up with a regular Gobi rack (not stealth) and fit into my two car garage with about 3 inches to spare.
Bill Z is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 03:45 PM #6
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I think you'll be in the neighborhood of 6'4" to the top of the OEM roof rails.
Old 09-23-2020, 04:19 PM #7
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I'm 6'3'' ish. Can't be.
My lifted TE with OEM rack is about 6'7'', although I managed to squeak into the SFO parking garage recently so posted clearances might have some wiggle room.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 04:31 PM #8
Jetboy's Avatar
Jetboy's Avatar
Height OEM according to Toyota is 71.5". Add say 3.5" net for lift and tires and you're only at 75" or 6'3".
I guess someone might have to measure? I'm basing my guess on the fact that I can still fit under the 6'8" garage height at work with my awning on that's about 3-4" tall on the side with 1.5" rear springs. With 2.75" rear coils I can't fit. So I figured without the awning I'd probably be right in the range of 6'4".
Old 09-23-2020, 05:00 PM #9
Photogr Photogr is offline
Photogr is on a distinguished road
14 TEP w/ 285/70/17's, 3" Toytec lift, Rhino Rack - Pioneer Platform which totals 77.5". My garage door is exactly 80" to the trim, so I have a little wiggle room for snow. My rack came with side rails, but they put me over the 80" in my current configuration so have been removed. I don't have a light bar, but if I get one it too will need to be low profile, ideally adding little or no height.
Photogr is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 05:04 PM #10
Crikeymike's Avatar
Crikeymike's Avatar
Hahhaa, you win today!!
Old 09-23-2020, 06:35 PM #11
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
I have a 2017 SR5 with 2.5 front 2” rear 285/70/17 with stock rack, i am at 6’4” or 76” at the top of the rack.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 08:35 PM #12
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
Sometimes people post things that are too accurate... This is one of those times.
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 11:41 PM #13
flyrv9's Avatar
flyrv9's Avatar
Just couldn't resist with the previous comment! However, there was a thread (I think it was here) where a guy raised the header on his garage and added a panel to the door to get the extra height he needed. Might be an option if there is room.
You can also get a little more height (inch or 2 +-) by adjusting cable tensions or springs. I replaced my springs a couple of years ago when one broke and learned a little doing it. Got to be very careful, messing with the springs, if you go this route.
Old 09-24-2020, 11:45 AM #14
Real Name: Sparky
Real Name: Sparky
2013 Trail Edition, Icon 3" lift, BFG TA/KO2 285s measures 6 feet 7 and 1/4 inches from the ground to the top of the OEM Trail roof rack.
I literally just measured.
Explains how I squeaked into SFO.
I swear it was almost 6'8" when the lift was new and it had slightly larger overall outer diameter Firestone 285s on it with fatter lugs.
Old and (c)rusty.
Old 09-24-2020, 06:50 PM #15
Do you know what the actual clearance of your garage is?
clearance , gobi , height , rack , smaller
Clearance Height on 265 KO2 and lift? bigbadpoppa 5th gen T4Rs 4 03-15-2020 09:38 PM
TRD Pro height/wheel clearance ? DatYoda 5th gen T4Rs 0 02-27-2018 03:42 AM
Ahh ... Height control and adjustable tail end height? coconutpete 4th Gen T4Rs 3 02-26-2013 11:49 AM
Clearance Height With Lift Tires and Gobi Stealth Rack Bill Z 5th gen T4Rs 18 11-29-2012 05:53 PM
Looking like more clearance... 88xtraSR5 3rd gen T4Rs 5 01-01-2011 12:19 PM
