Old 09-24-2020, 02:15 PM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
2016 inverter plug craziness
does anyone know why the inverter plug goes on and off when you put it in gear? i have a fast drone battery charger and tried to use the inverter to charge my drone batteries and the inverter is basically useless as far as i can tell,,,, what is used for it you can't use it while you are driving, which seems to be the case.
also,,my switch says 100w and also 400w,,, how do you know how many watts it is putting out?
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 02:47 PM #2
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I don't have an answer but same happened to me when I tried to charge my portable power station for a Colorado trip last month. Thought I'd be able to charge while driving but no. Works fine when in neutral or park though. I left it idling in park for about ~3 hours one day just to charge up a bit.
My power station will only let me charge at a max of 169 watts on AC outlet.
I've tested a floor fan to be working just fine while on and driving.
My guess is it won't let anything above 100 watts to be used while driving? I have no idea really.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 03:05 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
400w is only available with ignition on and in Park or neutral. 100w only when in gear. Mine appears to work fine at 100w while driving. If I try to draw more, it shuts off. To test it plug in a household lamp, under 100w and check to see if and when the light stays on.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 03:08 PM #4
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
That is normal, put in drive, power shuts off. 100/400 W has a selector button on lower left side of your dash.
If you look in your owners manual , it explains this "feature" (shutting off). I don't find the inverter all that useful because of this. Would be nice to use while driving.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 07:22 PM #5
meltdown meltdown is offline
meltdown will become famous soon enough
Inverter will work while driving. You just have to turn it on by pushing the button.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 09:06 PM #6
abbatoys abbatoys is offline
abbatoys is on a distinguished road
Thanks that is good to know. I just got a 2016 and am still trying to figure everything out.
abbatoys is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 09:22 PM #7
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
There is an easy mod somewhere on here to keep the invertor running at 400 watts when driving...did it to mine.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 11:29 PM #8
dont happen to remember what you did by any chance?
Old 09-25-2020, 10:09 AM #9
TOYO74's Avatar
TOYO74's Avatar
Sorry about my confused post;;I was thinking the OP wanted to use the 400W while driving. Only the 100W works while the vehicle is moving. The 400W works only while the vehicle is stationary and in P or N. Copy from Owners Manual:
■ Maximum available capacity of the power outlet
● While the vehicle is being driven
The maximum capacity of the power outlet is always 120 V AC/
100 W.
● When the vehicle is stationary
The maximum capacity of the power outlet varies depending on
the position of the shift lever.
• The maximum capacity is 120 V AC/100 W when the shift
lever is in any position other than P or N.
• The maximum capacity is 120 V AC/400 W when the shift
lever is in P or N.
The maximum capacity of 400 W can only be restored by turning the
power outlet main switch off and then on again with the shift lever in
P or N.
Old 09-25-2020, 10:51 AM #10
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Here’s one of the many threads that talk about the mod. Especially #26.
400W Inverter Mod?
Old 09-25-2020, 03:23 PM #11
Sky Sky is offline
Sky Sky is offline
Not exactly!
But I see @ElectroBoy posted a link.
That post #26 is exactly what I did and it worked on my 2019.
2011 FJ Cruiser TRD
driving , drone , inverter , plug , craziness
2016 trail version,, where is other inverter 120v plug? rockwind1 5th gen T4Rs 9 09-15-2020 05:06 PM
Inverter Plug Bumbo 4th Gen T4Rs 1 03-27-2017 12:59 AM
OffRoadWarehouse & Baja Designs Plug-n-Play 2010-2016 4Runner OffRoadWarehouse Off Road Warehouse 0 12-09-2016 06:45 PM
Power window craziness Tomjt 3rd gen T4Rs 15 06-26-2014 01:08 PM
WTB:Inverter,switch and plug imdav2u Want to Buy/Trade 0 05-27-2011 05:52 PM
