Old 09-24-2020, 03:46 PM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
Wire through firewall, what’s the easiest spot
Has anyone done this recently, is there a nice spot that maybe has a blank rubber plug in it that you can poke through or do you Gotta like poke a new hole through that one rubber plug but already has some wires going through it,, I just need toRun a power supply off the battery to something in the back
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 04:00 PM #2
photo8 photo8 is offline
photo8 is on a distinguished road
My 2018 has two. One is located below, and to the right Looking at it from the firewall side) of the ABS brake unit. It's a blind plug with a nipple, about 1/2" diameter. Exits just above the carpet line near the parking brake.
The other is on the passenger side and is a mirror image of the other. I think it exits behind the glove box.
You may be able to squeeze a wire through the main wiring loom grommet that's near the steering column, but it will be a very tight fit.
Make sure you use the proper gauge wire and fuse it near the battery.
photo8 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 04:37 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
easiest is passenger side firewall plug because there is less crap blocking the rubber plug on both the engine and passenger compartment.
Old 09-24-2020, 07:04 PM #4
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
Agreed, I have about 10 12 gauge wires plus cat7 wire on passenger side but also have 3 4 gauge wires going through drivers side grommets. both sides easy but passenger side easier.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 11:29 AM #5
tjones2k9's Avatar
tjones2k9 tjones2k9 is offline
tjones2k9 is on a distinguished road
tjones2k9's Avatar
On the passenger side there is a grommet where the rear wiper fluid line passes through (at least I think that’s what it is). It’s black in the engine compartment but changes to clear tubing in the cabin under passenger kick plate. Anyway, I fed the wires for my fridge through there. Just stretched the hole a little then pulled them through.
2012 Limited. Spacers on totally shot XREAS.
tjones2k9 is offline   Reply With QuoteReply With Quote
plug , poke , rubber , spot , wires
Best Place To Run 0 Gauge Wire Through Firewall? Kirk_B 3rd gen T4Rs 12 05-17-2022 05:59 AM
Where to run wire thru the firewall? Phx994Runner 3rd gen T4Rs 5 05-27-2012 02:40 PM
Running Wire Through the Firewall/Rubber Gasket in Firewall ts9790147 4th Gen T4Rs 4 04-06-2010 05:39 PM
How do I run wire through firewall? eskimochaos 4th Gen T4Rs 12 06-03-2008 07:15 AM
External Amp Power Wire thru Firewall ? XJeepguy Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-20-2008 03:00 PM
