Old 09-24-2020, 06:56 PM #1
Jrrrrr Jrrrrr is offline
Jrrrrr is on a distinguished road
Fluid Capacity
2020 4Runner
Transfer Case : What is the Part Number of Toyota 75 Weight Fluid?
And What is the Capacity?
Cooling System : What is the Part Number of Toyota Coolant?
Thank you 😀
Jrrrrr is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:42 PM #2
JeuTheIdit's Avatar
JeuTheIdit JeuTheIdit is offline
JeuTheIdit will become famous soon enough
JeuTheIdit's Avatar
Everything you need to know is in the maintenance quick reference:
DIY maintenance quick reference - Toyota 4Runner Forum - Largest 4Runner Forum
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
JeuTheIdit is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:43 PM #3
xyzzy xyzzy is offline
xyzzy will become famous soon enough
Google is your friend. Try it, you'll like it.
This link was one of many returned in about 0.76 seconds.
xyzzy is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:57 PM #4
@JeuTheldit, thanks for that 'local' link!
Old 09-24-2020, 10:55 PM #5
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
You have a new 2020 4R and no owners manual?
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 11:33 PM #6
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
how much blinker fluid do we need?
Old 09-27-2020, 12:52 PM #7
Is the Manual Accurate
Is the Manual Accurate for Front Differential, Rear Differential, and Transfer Case Drain & Refill ?
Old 09-27-2020, 04:51 PM #8
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Accurate for a dry fill, i.e. what they fill at the factory. If you drain those, there will be some residual left so it will take a bit less to refill.
fkheath is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 04:55 PM #9
2020 4Runner
Thank you 😀
The transmissions, differentials, transfer case, etc are now considered life time fill from the factory under normal operating conditions. Thus, you have many, many years, perhaps a decade or more before you will need to replace those fluids. So, I guess my question is why ask for a new 4Runner?
Old 09-27-2020, 04:56 PM #10
LOL. There is no blinker fluid needed in a 4Runner.
Old 09-27-2020, 05:06 PM #11
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
Are you 100% sure? Dont come here and spread false information.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 05:12 PM #12
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
ALL of it...
02SE is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 11:27 PM #13
Wifes 2014 2WD 4R differential capacity as listed in owners manual did not get it to the top. Had to add another 8 oz. or so. I fill rear diffs till they slightly overflow.
Do what you like with yours.
Old 09-28-2020, 12:24 PM #14
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
he'll listen to ya real fast as soon as he sees the price tag
1jzgte is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 04:30 PM #15
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Well that's just not true.
https://www.toyota.com/t3Portal/docu...-204Runner.pdf
"Front and Rear Differential Oil
Inspect or replace at specified intervals.
When performing inspections, check each
component for signs of leakage. If you
discover any leakage, have it repaired by a
qualified technician immediately"
"SERVICE INTERVALS (AS RECOMMENDED BY TOYOTA):
Differentials: 15,000 miles when heavily loaded, or with roof-mounted gear
Transfer case: 30,000 miles when driving dirty or dusty roads"
ATF: 90,000 miles
Toyota recommends that under “standard conditions” fluids be replaced as needed based on levels and color.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
capacity , fluid , number , part , toyota
Windshield washer fluid capacity? sf jakey 5th gen T4Rs 21 08-19-2020 12:26 AM
Auto Trans Fluid Capacity Help PrinceYota 3rd gen T4Rs 16 07-29-2013 05:17 PM
Brake Fluid Capacity? 07 2WD SR5 4Runner 4th Gen T4Rs 3 02-10-2013 10:18 AM
Tranny fluid and capacity 4Ronner 3rd gen T4Rs 5 08-09-2012 06:59 PM
Fluid Types and Capacity for 94 4X4 CAmaninacan Classic T4Rs 5 05-29-2012 01:09 PM
