Old 09-24-2020, 09:15 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Any issues disconnecting the battery?
I am following guide to install the OEM Audio+ speakers and one of the first steps is to disconnect the battery - am I going to have any issues doing this? Anything in the infotainment or other sensors going to trigger/get reset as a result?
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 09:57 PM #2
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
No issues. I disconnected mine a few times and never noticed anything.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 10:53 PM #3
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I've had the ground strap off of my wife's 2014 4R a number of times.
The first time you start the vehicle after reconnecting ground, the engine may stumble on first start attempt. Normal.
Mine always fires right up after the 2nd try.
You may need to resync your windows after disconnecting the battery. Not hard at all to do. Search around here for a how-to.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 10:59 PM #4
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
You may need to re-set your your power windows.
How To Fix 4runner Automatic Windows After Replacing Battery - YouTube
I disconnected my battery and and spent a week chasing gremlins until I did the reset.
Bill Z is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 11:01 PM #5
That's... an interesting gotcha! Looks straightforward enough and good to know if it ends up happening to me
Old 09-25-2020, 12:26 PM #6
If you want to watch the YT video - fine, but fast-forward 3 mins into it - skip all of the useless gibberish up front.
Here's a text write-up I put on an Avalon section at toyotanation.com awhile back. Pretty much the same across all models as far as I can tell. Worked on the wifes '14 4R and my '15 Tacoma.
Anytime the battery terminal has been disconnected, please initialize the driver’s door
power window and front passenger’s door power window after reconnecting the
battery terminal.
With ignition switch in the “ON” position, do the following:
1. Push down and hold the driver’s door power window switch to completely open
the window.
2. Pull and hold up the driver’s door power window switch until the window closes.
Continue holding the switch for approximately one second until the switch changes
from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open and close” function by fully
pushing the switch briefly to the “DOWN” and “UP” positions.
At this time the power window switch for the passenger’s door window should
be blinking.
4. Push down and hold the passenger’s door power window switch to completely open
the window.
5. Pull and hold up the passenger’s door power window switch until the window closes.
6. Check for proper operation of the “one–touch open and close” function by fully
Sunroof initialization is similar.
Old 09-25-2020, 12:31 PM #7
valleyforge.1777 valleyforge.1777 is offline
valleyforge.1777 is on a distinguished road
thanks for posting this info
sounds easy enough
does back window need same process?
valleyforge.1777 is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 12:41 PM #8
I believe the video shows the guy doing the back window the same way the fronts are done you may have to do that I just checked all five of mine and all went up and down with a single push of the button I only recall resetting my front windows I rarely have anyone in the back and hardly ever lower the rear window
Old 09-25-2020, 01:43 PM #9
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Yep, reprogramming the windows is about it, super simple
Old 09-25-2020, 01:47 PM #10
Whippersnapper02's Avatar
You guys had to reprogram windows? I removed my battery without issues when installing my OEM Audio system. Just remember that it may stall during the first start.
Old 09-25-2020, 02:14 PM #11
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
There is supposed to be a backup battery for all the settings, not sure how long it lasts, but mine has remembered all the settings when I've changed batteries.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 02:30 PM #12
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Either way, disconnecting the battery before doing any electrical work is a good idea. Since there are both switched and non switched circuits that share fuses; it's the only way to insure an accidental action doesn't cause problems. Sure you can check with a meter; but disconnecting the battery is the safest way. It can get expensive if you're not careful as a few previous threads will attest to.
Old 09-25-2020, 10:13 PM #13
zoomzoom's Avatar
zoomzoom zoomzoom is offline
zoomzoom is on a distinguished road
zoomzoom's Avatar
I had to, as the first step, disconnect the battery (negative terminal only) prior to starting the steps to remove/upgrade my fog-lights a few weeks ago. This ensures I couldn't accidentally activate, for example, the airbag sensors. After the upgrade, reconnected the negative terminal and no issues. Mine is a 2019.
zoomzoom is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 09:52 AM #14
phillyd2's Avatar
phillyd2 phillyd2 is online now
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
Done it a ton of times and never even heard of resetting the windows until now. LOL
The truck will stall after you first start it up but will be fine on the second time. No matter how many times it happens it still causes momentary panic.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is online now   Reply With QuoteReply With Quote
Old 09-26-2020, 03:00 PM #15
Bill Z's Avatar
Bill Z's Avatar
Ya, it's the strangest thing and there seems to be no rhyme or reason to it happening. I've disconnected my battery a bunch of times for various reasons and never had the issue. Last month I disconnected the battery to install LED interior lights. The install took me about an hour (the map lights were a ***** to get out). After I reconnected the battery my drivers side window would roll up half way and stop and the passenger rear window wouldn't roll down from the driver controls. I was racking my brain until I ran across a post on this forum that explained the procedure.
windows dont work after battery change
Auto window roll down feature stopped working
battery , infotainment , issues , sensors , trigger/get
Strange electrical issues related to disconnecting battery zopperman 4th Gen T4Rs 13 09-11-2014 12:30 PM
Preserving settings while disconnecting the battery Lewis&Clark 4th Gen T4Rs 5 09-08-2014 08:53 AM
Is it OK to arc weld on the 07 T4R w/o disconnecting the Battery jow 4th Gen T4Rs 17 06-27-2013 07:26 PM
Something to be said for disconnecting the Battery JP4RNR 4th Gen T4Rs 6 11-01-2007 07:48 PM
Disconnecting Battery overnight! msanta Problems & Warranty Issues 11 08-18-2005 02:17 PM
