Old 09-26-2020, 07:32 PM #1
volfan615 volfan615 is offline
volfan615 is on a distinguished road
Westcott TRD Pro Kit Installed
Had my Westcott Designs lift installed yesterday and then today installed 285/70 Wildpeaks and had alignment done. It looks great and actually rides better than before.
Measurements for center of hub to fender:
RF Before 21 - After 23
LF Before 21 - After 23.25
RR Before 22.5 - After 23.75
LR Before 22.5 - After 23.75
Before
After
Final result with 285/70 Wildpeaks
volfan615 is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 07:41 PM #2
plummerg's Avatar
plummerg plummerg is offline
plummerg is on a distinguished road
plummerg's Avatar
Looks great!
plummerg is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 11:26 AM #3
DENviaATL DENviaATL is offline
Real Name: Ken
DENviaATL is on a distinguished road
Real Name: Ken
Did you have to do a dif drop or anything else?
Ken
Denver, CO
2019 TRD PRO
This Is The Way
DENviaATL is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 01:22 PM #4
edgesalon's Avatar
edgesalon edgesalon is offline
edgesalon is on a distinguished road
edgesalon's Avatar
Before
After
looks great did you do the install or had a shop do it and may i ask how much to install the lift thanks
18 FunRunner
edgesalon is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 04:24 PM #5
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
Just found out about this lift today when talking to a local shop about lifting my 4runner. Super affordable in comparison to the other toytec/dobinsons lifts I was looking at. And I have a lower header in my garage so i'm worried when I have my ski racks on about getting close to the top of my garage after a lift.
On their web site it says it's not a spacer/body lift but having a hard time not seeing that. Did you have to do upper control arms to fit the 285/70/17 wildpeaks at all or just the lift?
JRod0981 is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 09:21 AM #6
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
Your rig looks great! Out of curiosity, what’s the finally ride height in the rear from the ground to the top of your TRD roof rack? I want to get this lift but I’m concerned about not fitting in my parking garage at work. The vehicle limit is 6’8”. I believe my rig is sitting at 6’5” with stock size KO2s.
I also want to get 285s but don’t want to mod the body, including removing mud flaps. Are you having any rubbing issues?
Stephencovar is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 10:15 AM #7
Brick Sprickly's Avatar
Brick Sprickly Brick Sprickly is offline
Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light
285s on a stock Pro will require some trimming if you don't have an accommodating lift beyond the standard Pro lift. You can go up to 275s w/o trimming.
2019 TRD Pro Voodoo Blue "Cobra Commander"
Brick Sprickly is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 01:14 PM #8
Do you think I’d need trimming if I were to go with the Westcott lift?
Old 06-19-2021, 02:50 PM #9
Rottwagon Rottwagon is offline
Rottwagon is on a distinguished road
I went with 285s with the Westcott and did not have any rubbing or require any trimming.
Rottwagon is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 11:35 PM #10
Yeah listen to Rottwagon as I have no experience with that lift.
Old 06-20-2021, 10:35 AM #11
This give be a lot more confidence in placing my order. May I ask, what is the final ride height from the ground to the top of the TRD Pro basket? I just want to make sure I fit inside the parking garage at work.
Old 09-25-2021, 02:46 PM #12
Sr. Carrots Sr. Carrots is offline
Sr. Carrots is on a distinguished road
Wonder how the ride is with the Westcott lift? Thinking about installing one on my ‘16 Pro.
Sr. Carrots is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 10:10 AM #13
spartacus's Avatar
spartacus's Avatar
Since you are in', " the state of confusion". i will copy it from the first post of this thread.
Old 09-27-2021, 12:26 PM #14
Ride quality; no confusions regarding ride height, but thanks.
285/70 , designs , installed , westcott , wildpeaks
new hho installed abigpicture 4th Gen T4Rs 54 01-03-2015 04:16 PM
Anyone installed HID?? Presta24 4th Gen T4Rs 6 01-22-2011 12:37 PM
Has anyone installed... OrionA1414 4th Gen T4Rs 3 05-25-2009 12:18 PM
6x9's installed? chayos00 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 09-21-2008 08:34 PM
