Old 04-23-2021, 03:10 PM #61
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Originally Posted by blackbearry View Post
Who is this Mark and how do I get a hold of him? I have a 2021 TRD Pro and was looking at the Eibach Springs over the Westcott Designs kit (the preload basically is compressing the spring more to give that lift and for off-roading, it likely will compress to 100% much sooner even if it bumps out first; meaning, the spring travel length is reduced). I think with the Eibach Springs, you get the lift and ground clearance, you get the stiffer on-road drive w/ reduced nose-dive, but you still have the full length of the spring to travel when compressed 100% off-roading.
Mark is with Eibach....according to PM comms with him, he will be notifying the group when the springs are ready.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 01:37 AM #62
blackbearry blackbearry is offline
blackbearry is on a distinguished road
Lift Kit - Factory Fox TRD Pro by Westcott Designs
Ok thanks. What’s his username so I can follow and keep an eye out for the post?
blackbearry is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 09:09 AM #63
Baystate4Runner's Avatar
Baystate4Runner Baystate4Runner is offline
Baystate4Runner will become famous soon enough Baystate4Runner will become famous soon enough
His username is ‘Mark@eibach’
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
Baystate4Runner is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 10:17 AM #64
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
You won't be disappointed with the Eibach.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 01:21 AM #65
Thanks dude!
Old 04-25-2021, 01:23 AM #66
Another question: I have the stock tires on my ‘21 TRD pro. With the current FOX suspension, could I fit the BFG KO2 285 tires on my current stock FOX and TRD 17” wheels?
What about after getting the Eibach springs installed?
Old 04-25-2021, 01:32 AM #67
lewdog998's Avatar
lewdog998's Avatar
Yes, they should fit without the eibachs...my 20 has the 21 front coilovers.....I just put 285 70 17 duratracs on mine, there was some minor rub on one side which ibwas able to fix with a heat gun...nothing else required. The KO2 is slightly smaller than 33, so it should be no problem.
I will be putting the eibach springs on when they are available.
Old 04-25-2021, 01:56 AM #68
Awesome, thanks man!
Old 04-25-2021, 01:58 AM #69
Another question: would adding 285 KO2 tires require me to get a new Upper Control Arm as I’m hearing of some people doing this? What about regearing ratios??
Old 04-25-2021, 02:39 AM #70
Jshen Jshen is offline
Jshen is on a distinguished road
Neither are needed.
Jshen is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 12:20 PM #71
lewdog998's Avatar
lewdog998's Avatar
Here is mine a couple weeks ago...great sand dunes nat park.... duratracs measure a full 33.....stock trd pro suspension...no uca upgrade.
Lift Kit - Factory Fox TRD Pro by Westcott Designs-20210419_122943-jpg
Old 04-25-2021, 12:36 PM #72
Awesome to see they fit!
1) Any rubbing or fender trimming needed?
2) Why did you opt to go with Duratracs instead of either BFG KO2 or Falken Wildpeak AT3?
Old 04-25-2021, 02:35 PM #73
lewdog998's Avatar
lewdog998's Avatar
Small amount of rub on driver front, pulled the liner forward a bit by unattached and reattached....fender liner / mudflap I used heat gun to push back and reset the shape.
Duratracs...like any tire you hear good and bad. I liked that they seemed to be slightly more aggressive in mud and the tread depth was 2/32 deeper than most. Also they have a 45k warranty (not sure about ko2 or falken)...also they are a full 33 inches O.D. Lastly every mall crawler here in Nashville runs nitto ridge grapplers...any i like to be different. Plus its not a mall crawler. I'm not a hard-core badass, but it has its share of pinstripes and gouges on the skids.
Old 05-25-2021, 11:08 AM #74
Zal4R Zal4R is offline
Zal4R is on a distinguished road
I am looking to do a lift on my 2021 Pro, but need to make sure it still fits in the garage. I saw some had the Westcott with 285's with the factory pro rack. How tall is the highest point on the rack with that setup (if you do not mind me asking). Can anyone give the same measurements on the Eibach springs with 285s (assuming 2020, since the 2021 is not out yet last I checked).
I know the Eibach springs are a bit stiffer, but are there any ride differences you notice with the Westcott lift? (Reading through I did not see anything major in that area for the Westcott)
Any help is appreciated.
Zal4R is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 09:17 PM #75
I don't know the exact measurements, but without the rack and just stock side rails I barely fit in my parents garage with the Eibach.
feedback , iphone , kit , leave , lift
Westcott TRD Pro Kit Installed volfan615 5th gen T4Rs 13 09-27-2021 12:26 PM
Factory 3in lift? Revtech? pktrusty 5th gen T4Rs 9 07-20-2016 06:15 PM
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
Lift Kit and Factory Warranty Joe_GT 4th Gen T4Rs 6 10-29-2004 06:30 PM
