09-28-2020, 10:15 AM
Nitto Ridge Grappler Tire Damage
I’m running 285/70/17 Nitto Ridge Grappler tires on my 4R. I just returned from a week long trip on the New Mexico Discovery Route. Most of the trails are either maintained gravel or hard packed dirt roads.
After this trip I noticed some of the lugs on the tires have broken off or are showing damage. I aired down to 20 psi while on the trails and aired back up while driving on any pavement. I only have 26,000 miles on my 4R and the tires are about 3 years old. Just seeing if anyone else has run into similar damage with these tires?
2017 T4R TRD Off-Road Premium, Metallic Gray, CBI Off-road steel bumper, CBI Aluminum Skid Plates, Smitty Built 10k winch, Fox 2.5 DSC/remote reservoir w/ Eibach 700# front coil spring replacement, Icon 2" rear coil springs with Sumo Springs, Prinsu Roof Rack, Rago Fab. Window Storage Panels, Method Wheels 285/70/17 BF Goodrich KO2.
09-28-2020, 10:20 AM
your general wear looks very similar to mine at about the same mileage as yours. are yours P, C, or E load?
09-28-2020, 10:36 AM
The tires are C load. I have used BF Goodrich AT, Good Year Duratrac and KO2 on my Jeep over the years and those have never shown that type of wear and the Jeep is my rock crawler and I air down from 12-18 psi regularly. This is the first time using Nittos so not sure if it’s normal or not.
09-28-2020, 10:50 AM
I have just over 50,000 miles on my Nitto’s with similar driving conditions as you state. They have been phenomenal! I just had them rotated a couple weeks ago and the folks at Discount Tire couldn’t believe how well they’ve warn. They measured at 11/32. I’m running 285/70 R17 c rated. They’ve been the best tire I’ve ever had for a semi aggressive style tire.
09-28-2020, 10:55 AM
For reference
09-28-2020, 11:44 AM
Yup that has been my experience with them as well on top of a couple of sliced sidewalls. Great tires for the street but not up to snuff for real off-road use imho.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
09-28-2020, 12:35 PM
I'd say that's consistent with my experience also. I only got 28,000 out of a set of 285/75 C tires and I had a ton of issues with my 305/70 E and gave up on them at 12,000 miles. Both sets chunked and had a lot of issues balancing. They were horrible in ice and snow.
It's a good looking tire but that's about the end of it. As
@ Xtremluck
said there are better tires for actual off road use.
09-28-2020, 11:15 PM
Thanks for all of the replies.
09-28-2020, 11:24 PM
yea they chunk out bad off-road. same issues on my E rated ones on the f250
09-29-2020, 09:55 AM
I have same experiences with the 305 E rated and can not imagine having C rated. they get torn up easily off road and I only have about 10,000 miles on them. I will not keep them much longer for trail use and only use them on the road. Good news or bad news I'm not sure (i'm happy), my 4R spends far more time off road then on.
09-29-2020, 01:54 PM
Looks accurate. The RG has soft rubber and tears relatively easily on rocky terrain. I got rid of my c-load RG a while back. Poor handling in snow and on anything wet. Decent on dry trails.
09-29-2020, 02:49 PM
These tires should definitely come with an air down warning. I have seen and heard of this quite a bit, especially from the people that air down for trails. Look for another tire next go around and you will be much more pleased.
Sent from my SM-G950U using Tapatalk
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
09-29-2020, 03:09 PM
Crazy to hear all these responses...I guess I found the perfect compound with regards to my Nittos. The light snow use I did have was not great but I don’t drive in the snow much at all. I’ll think real hard on my next tire purchase after reading these experiences. Perhaps I got lucky.
09-29-2020, 03:38 PM
Tires are a crapshoot. Some people with KO2s brag about getting 50k+ miles while I am going to have to replace mine at 40k. I may try the Atturo Trail Blade X/T. At least they aren't expensive.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
