Old 09-29-2020, 02:18 PM #1
sm4r sm4r is offline
sm4r is on a distinguished road
Upgrading to Fox TRD Pro Suspension... any other parts I should replace?
My 2011 Trail is about 4K miles short of 100K. It still runs like new but the suspension is starting to seem a little tired.
I recently swapped my KO2s for Falkens, moving from the 275s back to the 265s. I much preferred the look of the larger KO2s but I noticed the extra weight immediately – more sluggish off the line, rode a little rougher, gas mileage took a hit.
After a few years running them, I decided to switch back to stock. The change has been noticeable but also made it clear the tires weren’t the only thing to blame. The suspension needs to be updated.
I’ve ordered the Fox TRD Pro suspension. I didn’t want anything more than a small lift up front and the Fox set up seemed to have the most advanced tuning for stock configuration.
Yes, it was wildly more expensive but other than tires, brakes, and fluid changes I’ve spent nothing on maintenance for this car, so why not?
Questions...
In addition to the shocks and springs, are there any other common suspension wear items I should update while the mechanic in there? Bushings? Ball joints? Etc?
Anything else I need to know before making this upgrade (tricks, tips, etc)?
Thanks all!
sm4r is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 03:57 PM #2
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
Originally Posted by sm4r View Post
My 2011
Questions...
Thanks all!
If you have KDSS, replace the rubber bushings - they're about $8 each and you might as well do them when you unhook the KDSS sway bar during the suspension install.
Bill Z is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 04:53 PM #3
No KDSS. It’s a bare bones Trail. I was in a rush to get one just after the tsunami hit Japan. Recall it being one of the last ones left in SoCal at the time. Wasn’t sure how long production would be impacted.
Old 09-29-2020, 05:05 PM #4
edgesalon's Avatar
edgesalon edgesalon is offline
edgesalon is on a distinguished road
edgesalon's Avatar
I would changing the rear springs too
what did you get for rear springs?
18 FunRunner
edgesalon is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 05:15 PM #5
Yes, planning to replace the rear springs as well. Was just going to stick to stock springs since that’s what the shocks were designed against. I’m looking to retain the factory height in the rear.
Old 09-29-2020, 06:35 PM #6
lojack323's Avatar
lojack323 lojack323 is offline
lojack323 is on a distinguished road
lojack323's Avatar
Following along to see what tips you end up getting. Pocketing the info for the future lol
2015 SR5P. Two Graco car seats. Lots of cracker crumbs and dog hair.
lojack323 is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 07:35 PM #7
Adi4runner Adi4runner is offline
Adi4runner will become famous soon enough Adi4runner will become famous soon enough
You don't need to replace the rear springs, right? Springs don't really wear out like shocks... and TRD PROs use the same rear spring as all other trims (except Limited apparently).
2020 Super White TRD PRO
Adi4runner is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 08:34 AM #8
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
From what I'm reading bump stops might be a good idea.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 08:49 AM #9
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
You can go crazy with the “while you’re in there” stuff but at only 100k miles, unless you really beat in that thing off-road over the years, I’d probably just do sway bar end links and tie rod ends. They’re pretty cheap and easy to get to. You could do control arm bushings too but not sure if it’s necessary for that mileage or not and you’d need a press to replace them.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 09:24 PM #10
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
Questions...
Thanks all!
I replaced xRES on my wife's 2010 LTD with the 2019 TRD Fox take offs. also changed rear springs with the ones that came off the Fox set. Nothing else.
niadh0 is offline   Reply With QuoteReply With Quote
back , fox , ko2s , stock , suspension
Upgrading suspension? Timc03 5th gen T4Rs 8 06-03-2020 07:37 PM
Upgrading Suspension Pricing or TRD PRO? bigbadpoppa 5th gen T4Rs 48 03-27-2018 09:22 PM
Going to replace some suspension parts mplsdunk 3rd gen T4Rs 5 03-13-2015 11:44 PM
upgrading front suspension 4runnerAzGuy 4th Gen T4Rs 7 04-12-2014 04:47 PM
Upgrading the brakes on a '96 with '02 Tundra parts pencil_&_paper 3rd gen T4Rs 5 03-12-2011 05:13 PM
