I'm looking for help.
I've read that overfilling the transmission can lead to problems.
When doing a transmission flush, the normal strategy is to fill the transmission up and then run the engine until it reaches a certain temperature range (between 104-113 degrees Fahrenheit) and opening the check plug and letting the excess fluid drain out.
While that makes sense, while the ATF warms up, it's going to expand inside of the transmission pan. So, before the check plug is actually opened, the fluid is temporarily "overfilled".
So, is there anything wrong with LEAVING the check plug OPEN while the ATF warms up?
This makes sense to me, as doing a flush in this manner ensures that the ATF NEVER expands past the limit of where the check plug level is.
I only ask this because I've never seen this recommended before.
If you D.I.Y. your own transmission flushes, I'd love to hear your opinion of this.
Thank you!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual:
https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
